Old 01-07-2014, 07:27 PM
Stevarino's Avatar
Stevarino Stevarino is offline
Mein Auto: 2008 335 / 2014 X-3
Michelin super sport summer tires
It is too cold to use these tires for the next few days. The car is grounded!
Current Vehicles:
2017 440i Cv ED Sept 1, 2016 (ED #6)(PCD Oct 24)
2014 X-3 35i (PCD)
2008 E-93 335i Cv (ED #3) (Keeper)
BMW CCA #272524
Old 01-07-2014, 08:54 PM
Chop362's Avatar
Chop362 Chop362 is offline
Mein Auto: 2013 335Is
Tire Rack will tell ya no....But i say go. As long as no snow or ice.
Old 01-07-2014, 09:11 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
Most tires in this category include a warning about use in sub-freezing temperatures, even in dry conditions. The tread rubber loses its elasticity and a considerable amount of grip.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 01-08-2014, 04:21 AM
Banned
Mein Auto: 2007-335 HTC
just drive like a formula 1 drivers do for the first few laps to warm their tires up
Old 01-08-2014, 01:13 PM
Mein Auto: '06 AW 330xi
Traction will be reduced in temperatures below 40 degrees. You can drive with them, but any snow or ice and you won't be able to stop or start moving. Rain will also greatly reduce traction.
If you just need to get the car from point A to point B, just drive slowly. Take turns more slow than you normally would.
Old 01-08-2014, 06:45 PM
4Bimmers 4Bimmers is offline
Mein Auto: Z3,X5d,750Li,1200RT&C
Well that is news to me. I have Pirelli P Zero low profile 19" (30 and 35 profile) are they also cold inhibited?
For sure they are no ice or snow tires but they for sure should be drivable in cold as well.
Have a great day enjoying your ultimates
4Bimmers and 2Beemers
Old 01-08-2014, 07:23 PM
pointandgo's Avatar
Probably. You can go to Tire Rack's web site for this make/model tire and pull up Pirelli's warranty. The cold weather warning should be in there.
In my pre-retirement years I can recall several exotic cars that crashed due to driving on high performance tires in freezing temps.
The issue with high performance tire tread compounding and sub-freezing temps is related to the rubber compounding strategy and its 'glass transition temperature' (GTT). Simply put, it loses elasticity ability to grip the road surface.
The sensitivity to sub-freezing temps increases with even "higher" performance tires such as DOT "street legal" tires that will actually crack (like a frozen Snickers bar) in frigid temps.
Tire manufacturers have actually stopped shipping "street legal" type tires during the Winter months as they have been known to crack in shipping containers...certainly on cars that attempted to use them in frigid temps. Ice balls.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
Member: BMW CCA
Old 01-08-2014, 10:42 PM
Spagolli94 Spagolli94 is online now
Mein Auto: 2006 330i
I took my Michelin Pilot Super Sports off before the real cold weather hit. Not only was snow in the forecast, but those tires were starting to slip noticeably, even on dry pavement. Sure, you could always just take it slow and easy. But what if you have to make some kind of evasive maneuver? You can't always plan to brake nice and easy if somebody pulls out in front of you. You live in MD - you should be putting winter tires on the car from late November through mid-March.
Old 01-09-2014, 09:53 AM
ramblinman ramblinman is offline
Mein Auto: 2008 335
My first year in N/VA I used the oem Bridgestones in the winter. I didn't have a problem in the dry or wet, although I am sure the grip was less. I did have a lot of problems when rain turned to freezing rain on the commute home in the evening. I had very little grip, but was able to drive home slowly. After that experience I got winter tires on cheap rims now and they are much better in packed snow and ice. Plus, if I damage the rim, I will just get another cheap one. The only problem is ground clearance in snow, because there isn't much in a coupe with sport suspension. I think you can get by with summer tires in MD, unless you have snow or ice.
Old 01-09-2014, 10:16 AM
mitchelljnv mitchelljnv is offline
Mein Auto: CARBON SWARTZ 550i sport
In Las Vegas I can tell when it is in the thirtys in the mornings my super sports slip easily as I usually drive with the computer off on my550 by late morning in the sun in the fiftys it is much better. In the summer it is like being on rails and the launch is. Great. Under hard cornering they do chunk a bit. At Jackson barrier I did a ride along in a zr1 on super sports and they bunked also
