Old 01-07-2014, 08:28 PM
BEAMERZEALER BEAMERZEALER is offline
Mein Auto: 2011 335i xdrive
Belt noise or water pump going bad
up here in Washington state been cold for a while. When I first start up my 335i it almost sounds like a chirping noise for a while. Then a belt squeal when I give it a little gas. After it warms up for about 1/2 hour of driving its pretty minimal but still there. Just wondering if my pump is going bad or just needing a belt adjustment. Anyone else have this kinda problem ? In cold weather or if ever ?
BEAMERZEALER
Old 01-07-2014, 08:41 PM
Smalls1000's Avatar
Smalls1000 Smalls1000 is offline
Mein Auto: 2007 BMW 335i
Your water pump shouldn't be ran by a belt, It should be an electric pump. The 335i has an electric pump I know I just changed one myself.
Old 01-07-2014, 09:38 PM
floydarogers's Avatar
Pedant and Curmudgeon
Belt tensioner is going out, probably. As mentioned, water pump is not driven by the belt.
Old 01-07-2014, 09:51 PM
Taking it in this Saturday to have it checked out. Should still be covered under warranty
Old 01-07-2014, 10:10 PM
Fastpaddler Fastpaddler is offline
Fastpaddler
Mein Auto: 2016 Jaguar XF AWD Presti
A squealing water pump will have a worn bearing usually and you should get water on the ground from it leaking--if it is failing and they usually fail fast. Seems more like slipping belt. Belt tensioner should be checked if that is how your system is rigged. With change of weather sometimes a belt can squeal but I never recommend putting any dressing on the belt. That was old cliche solution which didnt work.
Old 01-08-2014, 03:10 AM
Banned
Mein Auto: 2007-335 HTC
Most likely a belt tensioner or idler pulley bearings going bad. the old squealing belts were the V type and squealed because they were slipping
