Old 01-09-2014, 06:14 PM
observer15 observer15 is offline
Mein Auto: 328xi
2007 328xi overheating in extreme cold weather
Hello -
Yesterday (-20F temps outside) on my way to work (10 minute stop/go commute) a loud fan came on. About 3 minutes later the yellow temperature gauge indicator came on the screen...followed by about 1 more minute and it turned red. I drove about another 100 yards, and the car wouldn't accelerate. I rolled to side of road, turned it off. I let it sit about 5 minutes. Started car back with no problems. No indicators on so I drove it about another quarter of a mile to my office, where it sat the rest of the day, and overnight.
Today, the temperature outside was 30f. I started it. Drove it home fine (5 miles). No lights. No fan. No issues.
My question is:
Can extremely cold temperatures cause issues like this with the tstat? Is it possible that the car didn't actually overheat, but that the extreme cold temps glitched something in the engine?
The nearest dealership is booked until next week, so I am hoping this is some fluke and nothing serious since it is acting fine now that the temps outside aren't as low.
Thanks.
Old 01-09-2014, 08:45 PM
Miller335 Miller335 is offline
Mein Auto: 2007 E92
I'd be getting the water pump checked out.
How many miles?
Old 01-09-2014, 11:39 PM
MP3_E46's Avatar
MP3_E46 MP3_E46 is offline
Code/wrench Monkey
Mein Auto: Carefully
How many miles?
+1. Your symptoms matches loads of people who have had the issue often at ~80K miles IIRC (of course it could be anywhere from ~60K to 100K+ depending how lucky you are). I believe there are codes to check for (google for other threads on this). Driving it far would not be wise; obviously stop if it happens again.
If you are luckily it could be just the thermostat. On these cars it's virtually always the water pump.
Six Euro Deliveries since December 1998 (Owned E46, E90, E91, E92 and E93)
28 vehicles in 26 years of driving so far. Guess I like cars
Old 01-10-2014, 03:38 AM
Banned
Mein Auto: 2007-335 HTC
so what it the temperature rating of the coolant in BMW"s it could be been slushy and just wouldnt circulate, then it finally warmed up enough to become liquid again?
Old 01-10-2014, 05:10 AM
Mein Auto: 328xi
How many miles?
68,000. Dealership service manager quoted me about $1100-1500 (parts/labor) if it is the water pump. He said we should replace tstat too if that is the case. They can't get me in until next Thursday, so until then it will be sitting in my garage. I am not anything close to a mechanic and neither is my boyfriend so I can't check any codes or do anything remotely technical. I will just have to wait and see I suppose. I am affraid to drive it and cause major damage (i've read head gasket blowing from driving cars with overheating engines?).
UGGGGHHHHHHHHHH
Old 01-10-2014, 06:25 AM
MP3_E46's Avatar
Code/wrench Monkey
Good point, now fully awake I see it said minus twenty which is -30C!! Few areas of the country saw that, I'd have stayed home. With a 2007 it's very possible coolant froze in places, did not circulate and led this this issue. I'd probably do for a drive keeping close to home and see what happens, shutting off immediately if the temp gauge hits yellow.
Old 01-10-2014, 07:02 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
As they say in Alaska: You betcha!
See, if you have an 'ecologically acceptable' 50% propylene glycol antifreeze, it freezes at -29F give or take a few for other components. Slap a wind chill on 'er and there you are.
But 50% ethylene glycol freezes at -36F, needing that wind chill t'slush yer ride. Once it does, you're gonna stop.
So. Extreme cold, and from your info we're not sure if you reside in, say, Sagavanirktok, Alaska [Prudhoe Bay] or Boston. But when Global Warming chills yer wah, you want to replace your water based charge with a true cold weather heat exchange fluid compatible with BMW metallurgy. Contact BMW Engineering at the Four Tubes in Munich, Germany.
For you Bimmerfest dare-devils, here's a photo of tourists traversing Prudhoe Bay during the cross country ski season:
Yup, Prudhoe Bay....right next t'Deadhorse and North of Coldfoot, it's an Alaska destination not to be missed! Accommodations available HERE
Old 01-10-2014, 07:06 AM
Mein Auto: 328xi
So, I talked to another mechanic (NOT the dealer). He said he felt strongly that if this was truly a water-pump issue, it would not have acted "fine" the next day when the temps increased by double. He said it would still be over-heating. He feels strongly that the extreme cold absolutely was the root cause. But did tell me to bring it in so he can check the coolant.
If it acts up again, I will pull over. Last time, it started with the fan coming on. If I hear the fan, I am stopping. I won't even wait for the temp indicator to come on.
Thanks for helping a girl out fellas. Didn't even have to bat my eyelashes.
Old 01-10-2014, 07:18 AM
Mein Auto: 328xi
I am in Cleveland, Ohio. We usually don't get as cold as it was Monday/Tuesday. External temperature on my dash said -14.. With wind gusts we were in the -20 to -35 range, at a total standstill. So this is not factoring the additional windshield factor when driving/moving.
I had the car serviced in July, including the coolant system (approx 3,000 miles ago). I am going to call them and find out about the antifreeze used and what the limits on it are.
Old 01-10-2014, 07:25 AM
Watchme Watchme is online now
Mein Auto: 2011 328i E90
windchill affects a car? hmm well they do "brrrr" sometimes, I guess
Old 01-10-2014, 07:27 AM
OK - here's the BMW MAN from Cleveland - check his Continental Divide ride and remember, this is a guy who rode in Prudhoe Bay in Sept - my wife won't go to Canada unless the last week of July or 1st week of August, and she's from the Great White. Maybe because....
Old 01-10-2014, 08:36 AM
Banned
if it gets that cold again, take the coolant overflow cap off, look in the top with a flash light and see if it looks like a slushy.
otherwise you can start the car, let it idle for about a minute, shut it off, wait about 3-4 minutes and repeat. you might have to repeat the procedure for 15 minutes to get it to thaw out
One winter when I was in College it was about 20 degrees out and I ask my dad " do you think I need antifreeze in my car?" He said yes DA. looked in the radiator and it looked like a slushy, Cranked the car, ran for a minute, turned it off, repeated several times till the engine got hot and the thermostat opened and started circulating hot water till it unthawed the radiator, drained the radiator and refilled with antifreeze and ran the car till it mixed
Old 01-10-2014, 09:07 AM
BostonB6's Avatar
BostonB6 BostonB6 is offline
Mein Auto: 2005 E85 Z4 3.0
Windchill does not impact a car. From NWS:
1. What is wind chill temperature?
A. The wind chill temperature is how cold people and animals feel when outside. Windchill is based on the rate of heat loss from exposed skin caused by wind and cold. As the wind increases, it draws heat from the body, driving down skin temperature and eventually the internal body temperature. Therefore, the wind makes it FEEL much colder. If the temperature is 0 degrees Fahrenheit and the wind is blowing at 15 mph, the wind chill is -19 degrees Fahrenheit. At this wind chill temperature, exposed skin can freeze in 30 minutes.
2. Can wind chill impact my car's radiator or exposed water pipe?
A. The only effect wind chill has on inanimate objects, such as car radiators and water pipes, is to shorten the amount of time for the object to cool. The inanimate object will not cool below the actual air temperature. For example, if the temperature outside is -5 degrees Fahrenheit and the wind chill temperature is -31 degrees Fahrenheit, then your car's radiator will not drop lower than -5 degrees Fahrenheit.
Old 01-10-2014, 10:33 AM
OK!
Let's hear how cows & Bimmerfesters can be windchilled but a BMW can't....?
Old 01-10-2014, 12:00 PM
ptrcd003 ptrcd003 is offline
Mein Auto: 328i LCI
The coolant shouldn't even start being affected until around -40 - it says so right on the coolant bottle (at 50% mix).
Old 01-10-2014, 01:51 PM
Vanos4:12PM's Avatar
Vanos4:12PM Vanos4:12PM is offline
Mein Auto: 2005 e60 6sp black/black
Since the water pump is driven by an electric motor now and not belt driven, could the cold weather cause a relay/switch, etc. to not turn on the electric motor for the water pump?
2005 530 6 speed/Sport/Prem/Cold black/black
2011 328i Sedan/6sp (lost to an accident and she is now at the big Roundel in the sky. )
1997 328i - gone "my first love"
BMWCCA # 367299
ED May 14, 2010
Old 01-10-2014, 03:34 PM
07lilredwagon 07lilredwagon is offline
Mein Auto: 07 e91
I agree its the frozen/slushy coolant at that temp....I just replaced a waterpump and they are indeed electrically driven...so they either work or dont work...not much inbetween. If it were the pump failing, you would have gone right to red with no yellow warning like mine did!
I very fortunately found a great independent mechanic 150 miles from home via an internet search from the side of the road and got the pump, thermostat, oil filter housing gasket, oil change, and coolant flush for about the same price range.
I think you have it figured out....
JP
Old 01-10-2014, 07:32 PM
AndrewHA AndrewHA is offline
Mein Auto: BMW 335xi Coupe
Happened to me few weeks ago when it was about 10F outside. Hasn't happened since, so I guess I'll just wait until the water pump fails.
Old 01-11-2014, 02:47 AM
MP3_E46's Avatar
Code/wrench Monkey
It's a 2007 so coolant has had a while to degrade
Old 01-11-2014, 07:29 AM
Let's not forget.....wind chill.
Question: Exactly how chilly does a radiator get when -30 wind chill, nose to t'wind, is compounded by a 40 mph increase?
Answer: If temp's -10 and prevailing wind's 15 mph, wind chill is -32F. Add 40 mph BMW forward velocity into the wind - wind chill now -46F.
Did you know: Wind Chill was originally based on the cooling rate of a small plastic bottle as its contents turned to ice while suspended in the wind on an Antarctic expedition hut roof?
The wind chill calculation above is based on a more modern formula, and is somewhat warmer than the original calc yielded. But for our radiators, the older calc may be more accurate!
Old 01-11-2017, 06:02 AM
1erbmw 1erbmw is offline
Mein Auto: 2006 325i E90
Hi observer15- mind sharing how you eventually fixed the issue? Sorry, replying to a 3-year old thread, but having the same issue now in Chicago under extremely cold temperatures. Thanks!
Old 01-11-2017, 09:29 AM
Tom K.'s Avatar
Tom K. Tom K. is offline
Unfortunately, since he only posted 4 times, the last one being 1/10/14, I doubt he is following this forum anymore. You might try to send him a PM.
Tom
Tom
Old 01-11-2017, 11:28 AM
Thanks Tom! I'll try PM'ing directly. -Saul
