Old 01-10-2014, 01:29 PM
1790ib 1790ib is offline
Mein Auto: 335 msport convertible
Please Help Charging fault and reduced power engine fault
I have recently had a new logic 7 amp replaced in my 335 convertible then 48 hours after my batery is dead, managed to jump it of another car then took it round the block to see if i could get some charge in the battery, whilst out the CHARGING FAULT came up on the idrive screen shortly followed by the engine fault with reduced power.
Could anyone tell me what might be the cause, heard a few people mention it could be the water pump/alternator belt might be damaged, or could it be something the audio place have done replacing the amp
Thanks in advance
Old 01-10-2014, 03:38 PM
07lilredwagon 07lilredwagon is offline
Mein Auto: 07 e91
hmmm...could be coincidence and your battery was close to failing anyway....you can have the battery load tested to see if it is in good health. I would do that first.
There may be a draw on the battery from the new amp, so I would take it back to the place that did the work for a system check.
I have not heard of a water pump causing this problem and is probably unrelated...the alternator can be tested too to see if it is putting out sufficient charge...I think somewhere around 12.5=14v is about right.
JP
Old 01-10-2014, 04:34 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
First things first.
I'll save you a Google....uh, have you Googled? Surely you've Googled. Have you?
HERE - view videos
HERE - more better, a multimeter in the 4th dimension. View and see the point!
Old 01-10-2014, 04:36 PM
OK!
Now that your data's in, how did you hook up your new amp? Wiring diagram, please.
Old 01-11-2014, 12:34 AM
Not sure how the amps wired as I had a audio shop fix it
Sent from my C6603 using BimmerApp mobile app
Old 01-11-2014, 12:36 AM
Thank you I'll do that, it worked fine going into work and during the rat of the day then came home, 2 hours later it's dead
Old 01-11-2014, 03:33 AM
Turns out that water has managed to get in somewhere and this had got into the well where the battery is in the boot and corroded the two battery points, which was the same issue i had with the amp on the opposite side
Old 01-11-2014, 07:36 AM
Knowing that terminals sit on the battery top, did the well completely fill with water?
Old 01-11-2014, 08:02 AM
No at the bottom there are two battery points that run through to the front of the car jump start points they been submerged and corroded, there was a good couple of inches of water in there
Old 01-11-2014, 08:04 AM
