BMW ISTA/D Rheingold - Bimmerfest - BMW Forums
Closed Thread
Old 01-13-2014, 10:41 AM
inspi inspi is offline
Mein Auto: 03 BMW 745i, 06 BMW 750Li
Run straight in Windows, it's very quick. If You use DIS, then You can use same OBD cable with this software. With all repairing instructions, wiring schemas, etc. PM for details
INSPI
Old 01-13-2014, 11:34 AM
MOPAULY's Avatar
MOPAULY MOPAULY is offline
Mein Auto: Many things
Is this a replacement for INPA? Is this not something I can purchase through the BMW service subscription?
Old 01-13-2014, 11:39 AM
It's original BMW diagnostics software and it's not for sale thru BMW
INSPI
Old 01-13-2014, 11:52 AM
MOPAULY's Avatar
so it's older than DIS/TIS/PROGMAN/SSS? I'm confused...
Old 01-13-2014, 11:58 AM
Nygel's Avatar
Nygel Nygel is offline
Mein Auto: BMW 750Li
no its newer. ISTA/D replaced DIS and ISSS/P replaced Progman
Old 01-13-2014, 12:03 PM
Yep, It's the latest soft
INSPI
MOPAULY's Avatar
hmmm for $250 I think I'll stay with my $15 cable and current software set
Old 01-13-2014, 12:10 PM
Nygel's Avatar
That's where I will be heading next. It will work on newer models also. The ICOM is the real expensive part, but with it you can update certain ECU's thru the MOST, the way they were suppose to be update, DCAN is to risky and takes forever and have issues with power swings.
Old 01-13-2014, 12:12 PM
I have also ISTA/P 2.51.0 with ICOM use only.
INSPI
Old 01-13-2014, 08:16 PM
PAPER's Avatar
PAPER PAPER is offline
CRISP & CLEAN
Mein Auto: Ford Pinto
Why are you charging so much when this software is
already available for much cheaper ???
Old 01-13-2014, 09:37 PM
Emeer18's Avatar
Emeer18 Emeer18 is offline
Mein Auto: 2013 BMW 750 LiX
I plan on hacking this software and making it easily available for everyone soon. DIS and INPA are to complicated to use efficiently, thou i have mastered them.
Old 01-14-2014, 03:03 PM
Ltmax's Avatar
Ltmax Ltmax is offline
Mein Auto: 2008 750l
Sweet, can't wait. Until then I'll have to stick with my cheap bootleg software and cable that cost $35 as $250 for pirated stuff from Czech Republic is a little too expensive for me...
Old 01-14-2014, 06:31 PM
rippjd rippjd is offline
Mein Auto: '05 745i / '10 X5 35d
I've only seen native installs on certain laptops or VMWare which requires a 64 bit Host OS with 8GB of RAM so that the Guest OS can use 4 GB... so running straight in Windows sounds interesting. A few questions I'm sure others are wondering (though I suppose you could respond via PM):
1. What are the recommended hardware requirements? And with those requirements how many minutes of boot time for ISTA/D?
2. What is the process for printing?
3. Is an activation code required? How many "days remaining" do you get before the code expires?
4. What are the upgrade options? And the cost, for example when you have ISTA/D 3.40.X running straight in Windows?
5. Is F-series supported? E-Net cable required?
6. What screen resolutions can you run? It's nice to run WDS on a 20"+ screen...
7. Does KL15 & KL30 report actual voltage through the Ediabas interface?
Thanks.
2005 745i Individual
E65/E66 Parts for Sale:
Alpina Type 743 Front Spoiler complete retrofit kit (new in box) $1200
Old 01-15-2014, 07:12 AM
ad 1) Nothing special, it run on old laptop with XP and 2 GB with no problem. It take about 30 sec. to start ISTA/D
ad 2) You can print to the printer connected to computer or to the PDF file
ad 3) Activated till 2072
ad 4) No upgrade, you have to install new version
ad 5) F series with ENET cable or with ICOM
ad 6) ISTA/D have resolution 1024x768
ad 7) On some car it's recognized, with ICOM fully supported
INSPI
Old 01-16-2014, 03:21 PM
Emeer18's Avatar
Well i've found download links to obtaining the necessary software. We will see how this goes
Old 01-26-2014, 09:27 PM
Emeer18's Avatar
Might not have to wait that long, i've got it running on my Pavilion with dual core cpu and 8GB of memory 1TB HDD, it uses 120GB of. The only thing i have to do is confirm it connects to my 7 and does everything its supposed to. It does use almost 100% of the cpu's and 50% of the ram. Its so simple to use, it makes DIS and inpa look ancient!
Old 01-26-2014, 09:59 PM
Romey-Rome Romey-Rome is offline
Mein Auto: 750li
Heh. Grab a torrent. There's also an icom emulator vm out there dongle free. Just load the vm snapshot with the app already running. Works with my K+DCAN on OSX.
Old 01-27-2014, 12:05 AM
But Your software running in Virtual machine
INSPI
Old 01-27-2014, 12:19 AM
Mein Auto: 750li
Doesn't bother me. With 16gb of RAM & SSD, I notice zero difference. Suspend it, & it starts up in like 5 seconds. I mean - how often do you actually use it?
Old 01-27-2014, 04:52 PM
Emeer18's Avatar
Thats what im looking for, dongle free.
Old 01-27-2014, 05:10 PM
Mein Auto: 750li
ICOM Emulator VM: https://mega.co.nz/#!Q5Zn1RJQ Download Key: CbatSyuo6EppMYKFjSeFgFa_1d5KQQ7cbIHgFdSorLw
You have to start it up from one of the snapshots where the app is already running preconfigured for your cable type. It only check the dongle on startup of the app. So basically, it just gets around it by saving a state with the app already running.
The 2 "Working" snapshot I made for my own purpose. It comes with OPS, DCAN, & ENET running states.
Not sure there's a dongle workaround if running it native.
Name:	Screen Shot 2014-01-27 at 5.05.26 PM.png
Old 01-27-2014, 05:34 PM
Emeer18's Avatar
https://mega.co.nz/#!Q5Zn1RJQ Key: CbatSyuo6EppMYKFjSeFgFa_1d5KQQ7cbIHgFdSorLw
Im a little confused as to what the icom emulator is for. Im assuming its just like Diag head emulator for DIS? And the purpose is for it to establish the connection to the car?
Old 01-27-2014, 05:46 PM
Mein Auto: 750li
Yep. Pretty much. ICOM communicates over the standard network. Not sure if that was the case with DIS. Never played with it.
Whoever made it for the ICOM tried to secure their revenue stream with a dongle.
Old 01-27-2014, 07:31 PM
Emeer18's Avatar
So did ISTA D/P replace DIS/Progman/TIS? Ive got ISTA-D_2.36_ISTA-P_2.50.2 running on the Virtual Machine. And just to clarify that im correct for it to connect to the car with the K-DCAN cable i need to use the ICOM Emulator but it wont work without a usb dongle. And to bybass the usb dongle i need a screenshot, if so a screenshot of what? The screenshot you attached was difficult to see.
Old 01-27-2014, 08:29 PM
Mein Auto: 750li
You're correct up to the "I need a screenshot". Screenshot alone won't get you anything.
I provided a link for the emulator in post 21. It's about 1 gig file. It's a preconfigured virtual machine, with 3 different snapshots.
For it to work, you'll need to be running BOTH virtual machines. ICOM Emulator & ISTA. The emulator is pretty slim, and doesn't require much resources. It just sits there & translates. It your case, you would load the "K+DCAN Start" snapshot from the ICOM Emulator VM.
Closed Thread
