Closed Thread
Old 02-16-2014, 11:10 AM
mybmw408's Avatar
mybmw408 mybmw408 is offline
Mein Auto: BMW 750i
Ok how about an install tutorial ????
I have both files
  #52
Old 02-16-2014, 02:49 PM
terahertz terahertz is offline
Mein Auto: E90 M3
Could someone who downloaded it reupload it to mega.co.nz? The link is down! Thanks!
  #53
Old 03-06-2014, 11:44 AM
MR B Mera MR B Mera is offline
Mein Auto: 11 x5 35d,13 Spyder STS
Originally Posted by MOPAULY View Post
Got it installed and working today, used it to clear my codes after replacing my seat foam; the coding option is greyed out, guess I need to read through and see how to get that working. So much nicer than the old software!
hi, did u have to do a comp port setting for this? my inpa was on port com1 i think! thanks.
  #54
Old 03-06-2014, 01:12 PM
MOPAULY's Avatar
MOPAULY MOPAULY is offline
Mein Auto: Many things
I used the same com port as before, COM1 for me - but this laptop still has a physical 25 pin port and is not using USB for the connection.
Old 03-06-2014, 02:26 PM
HerbP HerbP is offline
Did you run this in VMWare, or what operating system? I would like to get this running, but it crashed my computer on the last attempt. I downloaded the Rhinegold 3.41 ISTA/D version on Mega. Which version did you use?
  #56
Old 03-06-2014, 02:31 PM
Nygel's Avatar
Nygel Nygel is offline
Mein Auto: BMW 750Li
It's native. It runs on any, it is a little over 9gb. Do not install on a pc that you use daily for personal use, get a pc with descent specs to run this solely then you would not have any issues.
  #57
Old 03-06-2014, 03:46 PM
i have a usb cable, ill try to hook up tonite and see what happen! i kinda remember reading somewhere that they change to port com9! thanks...
  #58
Old 03-06-2014, 04:41 PM
Originally Posted by Nygel View Post
It's native. It runs on any is, it is a little over 9gb. Do not install on a pc that you use daily for personal use, get a pc with descent specs to run this solely then you would not have any issues.
What kind of specs would be needed. This make sense why it crashed my laptop. I have 2 older xp machines that I could possibly use, but I might need to upgrade the ram?
  #59
Old 03-06-2014, 05:18 PM
im running winxp 32 in bootcamp off macbook pro, seem to be running pretty smooth without connect to the car,,,
  #60
Old 03-07-2014, 01:20 AM
inspi inspi is offline
Mein Auto: 03 BMW 745i, 06 BMW 750Li
I have it on my everyday use laptop without any issue
INSPI
  #61
Old 03-07-2014, 01:21 AM
Emeer18's Avatar
Emeer18 Emeer18 is offline
Mein Auto: BMW 745Li
What version do you have? Are you able to diagnose and program? And are you using it in a VM Ware?
Old 03-07-2014, 02:49 AM
I'm using software from my original post. Diagnostics aplication running straight under Windows
INSPI
  #63
Old 03-07-2014, 02:50 AM
Emeer18's Avatar
Attachment 426730
Attachment 426731
Where did you get your software?
Old 03-07-2014, 04:16 AM
That's my own build, source from BMW
INSPI
  #65
Old 03-07-2014, 04:27 AM
Emeer18's Avatar
Do you know anything about programming such as vehicle import order? Im not even sure what it means but i have programming on my version and im trying to program my 750
Old 03-07-2014, 04:32 AM
In ISTA/P You can import VO/FA, You can prepare VO in editor.
Or simply add $ to VO in NCS Expert.
Then recode car
INSPI
  #67
Old 03-07-2014, 04:38 AM
Emeer18's Avatar
Then recode car
Is it necessary to import, what does it actually do? Maybe its easier to use NCS Expert for programming.
Old 03-07-2014, 04:43 AM
You have to import VO with changes
INSPI
  #69
Old 03-07-2014, 04:46 AM
Emeer18's Avatar
Got it, make sense i think
Old 03-07-2014, 07:21 AM
Nygel's Avatar
@inspi that is not what I mean, for the individual that is not a computer wizz, a dedicate pc would not have additional software that can cause issues such as virus protection, updates etc.
Old 03-07-2014, 08:13 AM
One computer is enough for me
INSPI
  #72
Old 03-07-2014, 08:30 AM
mybmw408's Avatar
Mein Auto: BMW 750i
Ok I have both downloads from when this thread started. Have not installed yet. Any tips for install, or is it straight forward???
Also can I still have my other Programs on my computer (dis/gt1,inpa,) obviously there are more programs, just example. I'm only using the laptop for my car.
  #73
Old 03-07-2014, 08:39 AM
I didn't provide any downloading links, so i don't know what You have
INSPI
  #74
Old 03-07-2014, 08:42 AM
mybmw408's Avatar
Mein Auto: BMW 750i
Emeer18 directed me toward the links to download.
  #75
Old 03-07-2014, 09:04 AM
Like I said, I don't know what You have. Anyway, install is easy, You need .NET Framework and EDIABAS installed, so You can keep all programs with that
INSPI
Closed Thread
