Can't get eibach springs on strut tower - Bimmerfest - BMW Forums
Old 01-17-2014, 01:41 AM
WhiteFury's Avatar
WhiteFury WhiteFury is offline
Booooost!
Mein Auto: 2011 335i N55
So I got the Ibach Pro Kit 2092.140. I have a 2011 E90 XI.
I have done many suspensions on all my cards. For some reason I can't get the spring to compress enough and when I took the factory spring off it pop because the spring compressor didn't seem to compress that spring either.
The Ibach spring seems really long and would have to be compressed down to Half it's size, is this normal?
I checked the driver side and it seems the strut is much longer almost as if the spring expands the struts when the car is jacked up is this what happens?
Here's a picture of my strut, the Ibach spring, and my bring compressor. I may have to go to AutoZone to rent their spring compressor as it's much closer together and will get me a lot more spring compression.
JB4 Stage 2 | Injen CAI | BMW PE | AR Catless DP | Alpina TCU Flash | Eibach Pro Kit | Custom TCKline Koni's | 19" RS7 Wheels | DWS Tires
Old 01-17-2014, 03:51 AM
Banned
Mein Auto: 2007-335 HTC
are you sure you got the right springs? I would think if they were replacement springs no change in spring rate they should be the same length, since you didnt show both springs its difficult to tell what you are talking about
Old 01-17-2014, 08:06 AM
WhiteFury's Avatar
Booooost!
These springs are shorter. They are the 2092.140
Old 01-17-2014, 08:21 AM
Mein Auto: '06 AW 330xi
Take the top spring mount, slip it over the top of the spring, then compress the spring with the spring mount. Then you can mount the strut hat.
The compress tool hooks should hook over the spring mount.
Old 01-17-2014, 09:09 AM
WhiteFury's Avatar
Booooost!
So I went to AutoZone and borrowed their spring compressor which is just tight enough to get the hat on. However the top bolt I cannot turn as it turns the hex nut inside, I have no way to turn both the same time because I can't fit a wrench in that what should I do?
Old 01-17-2014, 09:54 AM
WhiteFury's Avatar
Booooost!
I ended up getting it snug and then installing it and then jacking up the bottom of the router to compress the spring with the suspension and I was able to tighten the bolt down.
Old 01-17-2014, 03:41 PM
WhiteFury's Avatar
Booooost!
So everything is complete. Looks good but not fully settled. It didn't look like a full drop yet.
I must say these springs are more comfortable than the factory springs!
I don't know how it is with the "I" model I do know that my car drives a lot smoother and it's a lot more planted over bumps. My factory springs would bounce the car all over the place and was kind of harsh these springs are planted and soft.
Another thing I actually noticed that the springs of the car corners, and breaks so much better! It doesn't nosedive and it just overall is more pleasing to drive.
