Old 01-18-2014, 10:46 AM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
bimmerfest Supporting Member
Mein Auto: A redhead E90
2006 E90 powerfolding mirror issue: reset didn't work.
Hi all,
I recently ran into the issue where the driver's side mirror folds all the way forward upon unlocking the car or unfolding the mirrors. At first I thought someone may have bumped into my mirror and it was just "lost". I looked up how to do the reset, and tried that a few times but there was no joy. The threads on E90 post were less than useful, with most people saying to just "cut the power wire" to the mirror motor.
I'm now beginning to think that the stop inside the mirror body is probably broken and that's why the mirror doesn't stop where it should. I guess now my only other option is to order whichever part i need to replace and go at it one of these days. This is where I'm lost now, I have no clue what I'm looking for or where to order it. I'd really like to not pay the dealer to fix it because it'll be 80 bucks for the part and 200 for labor or something absurd, and something that I am more than capable of repairing myself.
Any help is greatly appreciated, thanks.
Originally Posted by Los View Post
^He's been drinking beer and destroying pumpkins with brake rotors and sledge hammers.
So, pretty much just doing man stuff.
  • '06 325xi 6MT
Old 01-18-2014, 01:34 PM
spastook spastook is offline
Mein Auto: 2007 BMW 328xi wagon
Same issue with my 2007 328xiT. Only on passengers side. Goes all the way forward. If put it all the way folded in manually, then start the car and it returns to its correct position. If I use the switch to fold the mirrors in again upon folding out the passenger side goes all the way forward again. So I just stopped using the feature.
Old 01-18-2014, 01:52 PM
Kdoherty's Avatar
My problem is that, but also, it does it automatically whenever i open the door, when it does the "position check" i tried to slide the selector over to see if that would at least prevent it from moving, but it doesn't.
When i reset mine it "pops" in at the folded position but fails to stop at the normal driving position each time. So i'm guessing something is broken and not in need of resetting. it's rather embarassing to have to catch the mirror every time i get in the car
  • '06 325xi 6MT
Old 01-18-2014, 08:05 PM
AzNMpower32's Avatar
Tar Heel Faithful
You are right. This happened on my mother's 325i as well; the mirror would fold too far out when unfolding and sometimes keep trying to fold in even after it was supposed to stop. The plastic stop inside the mechanism was broken. Luckily this was covered under CPO warranty......they replaced the entire mirror mechanism. Not cheap at all if paying on your own.
Old 01-18-2014, 09:02 PM
Mein Auto: '06 AW 330xi
You can find part diagrams and part numbers on realoem.com
Take the part number and enter it into the search of a parts site. I like to use ecstuning.com but sometimes, their shipping kills the deal.
Old 01-19-2014, 02:13 PM
Kdoherty's Avatar
alright, i'll go and scour ECS for the part and figure out how it's done. I typically DIY all my stuff because I used to be a dealership tech, but now that i've switched careers and don't have an indoor garage I usually just take the "nice" car to the dealer and save the DIY stuff for my E36. If it's going to cost a monumental amount of money though for something that small I'm just going to suck it up and spend an hour or so in the cold.
  • '06 325xi 6MT
Old 01-20-2014, 03:41 AM
Westech's Avatar
Westech Westech is offline
Mein Auto: '00 Z-3 '06 325ixT
Hi all,
Try www.realoem.com or www.pelicanparts.com fdriller9 is correct, ecs tuning shipping can ruff up your wallet. I like their products and their delivery time is fast but $$$$. Google search will give you instructions.
Old 01-01-2015, 03:02 PM
bagatrix bagatrix is offline
Mein Auto: 325i - 2006
Fix to Auto-folding Mirror - This worked for me
Much like most people trying to find a fix for auto folding of their mirrors evertime they unlock or lock the car, i have a suggestion you can try below. This worked for me and i had tried all the other ways that others have posted which to my dismay did not resolve the problem.
I also was thinking of cutting the wire to stop this issue and figured what's the harm in trying to just fix it.
I took the following steps in this order:
1. Ensure car is locked and your mirrors are in their normal position. Which you would've done manually last time you used the car.
2. Unlock the car and they will fold outwards. Both passenger and driver side.
3. focus only on fixing the driver side the proper way and don't worry about the passenger mirror
4. Take the manual key out of your fob and lock the car until both mirrors fold inwards
5. unlock the car by holding the unlock button and having all your windows come down. I did this till all four windows were down, mirrors folded outward (of course) and part of my sun roof opened.
6. fold the driver side from the outward position to inward until you hear a click. don't bring it all the way in and it will look like its still not in the proper place.
7. leave your passenger side mirror in its outward position
8. lock the car normally with the remote, wait few seconds and unlock.
9. mirrors should not move outwards -
10. manually adjust both mirrors in the position that you use for driving
Drive!!!!!!!!! oh felt sooo good that i fixed this issue in -10 degree weather!!!!!!
Old 01-01-2015, 07:22 PM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is offline
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
Whelp, came across this index of folding mirror issues and resolutions!
e90, power folding mirror issue
