Pad and Rotor Suggestions - Bimmerfest - BMW Forums
Old 01-18-2014, 03:37 PM
Jeff Sterling Jeff Sterling is offline
Mein Auto: 2007 335i
It's time to replace the pads and rotors on the 2007 335i.
I'm not a tuner but I'd like to get something a bit more performance oriented.
Obviously brake dust is always a pain, but it would be nice to increase my braking ability.
Does anyone have any brands they like or items they have had success with?
Thanks.
Old 01-18-2014, 08:45 PM
Mein Auto: '06 AW 330xi
At the shop I work at, we install Hawk HPS pads on many BMWs and Minis. All our customers have been happy with the performance.
I can't comment on the dust as I've never personally ran them on my car. I am however going to install a set once my brakes need to be changed.
As for rotors, any Brembo, Centric, Powerslot, etc are fine
Old 01-18-2014, 09:29 PM
wjjklj's Avatar
wjjklj wjjklj is offline
Mein Auto: 2013 BMW M5
Akebono Euro Ceramic pads = zero dust
Old 01-19-2014, 12:30 PM
blue boy's Avatar
blue boy blue boy is offline
Mein Auto: 2011 328ix
like wii said
surely goodness and mercy will follow us all the days of our lives
2011 328IX
Ford 150
Gen 3 Prius
Goldwing Trike
Mustang with mods
Old 01-19-2014, 02:38 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
I use Hawk HPS for track weekends and in that application I quite like them. Performance and feel seemed pretty consistent on the track (at high temperatures) and on the street (ice cold), at least for a track novice. (More advanced track rats think they're not enough pad--who am I to argue?--but I'm not there yet.) They are considerably dustier than OE and the dust has a much higher iron content (read: they're a bit harder on rotors than OE). A heavy accumulation will rust quickly and may be a bear to clean off, but weekly cleaning should be fine unless dust just drives you mad.
On the street, in normal driving: I hate them. In case anyone missed that I'll repeat it: I hate them. Compared to OE pads, I found the Hawk HPS to have less initial bite, produce more dust and require slightly more pedal effort for equal braking in day-to-day, leisurely driving.
On the street I just didn't find them superior in any way to the OE pads, either before or after they'd been thrashed at the track.
Why, exactly? Let me rephrase that: How, exactly?
The stock brakes are powerful enough to get you into full ABS braking, even with hot tires on dry pavement, even dead cold. Stopping distances with high-performance summer tires are equal or shorter than most sports cars. (If you really know how to brake, you will be forever more worried about the traffic behind your BMW than most anything in front of you.) They have more than enough fade resistance for any sane driving you'll do outside of a racetrack. Best of all, they have superb cold "bite"--meaning when some idiot cuts you off and you need all the braking you can muster, right now, they'll deliver. Many high performance pads will not, because their design favors high-temperature stability and fade resistance over maximum cold stopping power.
Shorter stopping distances? Longer pad/rotor life? Less dust? A firmer or softer pedal feel? A less "touchy" feel on initial braking--or more so? All of the same when hot vs. cold? Do you want more fade resistance? More stable braking on wet rotors? On and on.
BMW brakes are among the best in the business, right from the factory. Before making changes, have a clear idea of the characteristics you want to improve, and what trade-offs you are willing to make to achieve those goals. Then you can make smart choices.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 01-19-2014, 02:53 PM
dmatre dmatre is offline
Mein Auto: 2011 E90 328i
I would go with the latest pads from BMW. Seems they changed in '10 or '11, and now they have almost no dust, great initial bite, and good fade resistance.
They're not race pads, but they're the right tool for the job on the street.
Old 01-19-2014, 03:22 PM
Saintor's Avatar
Saintor Saintor is offline
Abuser of everything
Mein Auto: BMW-less for now
My life quality improved since I have been using them.
Old 01-19-2014, 06:48 PM
4Bimmers 4Bimmers is offline
Mein Auto: X5d,750Li,1200RT&C
What rotors do you use with ceramic pads? Carbon or steel?
Have a great day enjoying your ultimates
4Bimmers and 2Beemers
Old 01-19-2014, 07:11 PM
You can't afford carbon....
Steel is fine. If you tend to warp them, try cryo-treated.
brake dust, brake pads rotors
