Old 01-19-2014, 08:54 PM
wjjklj's Avatar
wjjklj wjjklj is offline
Mein Auto: 2013 BMW 750Li X-Drive
Replaced Low Pressure Fuel Sensor
I used the scanner below to pull the error code for low pressure fuel sensor. Pretty easy DIY. No need to remove the intake manifold. I removed the charge pipe, air filter housing, throttle body, and the cowl. Once removing these pieces the sensor was readily available. The car was a 2008 335i.
ID:	417958Click image for larger version
