Old 01-20-2014, 09:37 AM
dmmr dmmr is offline
Mein Auto: 2008 328i
2008 328i Battery Light
Yesterday evening I parked my car, turned the engine off but continue to charge my phone via car charger. 20-30 min later, the battery warning light appeared. I have been able to start, drive the vehicle without issues nor battery light warning.
Is this just a warning indicator since the engine was off but battery used continued?
Old 01-20-2014, 10:49 AM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
Sign of a dying battery
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 01-20-2014, 11:20 AM
Mein Auto: '06 AW 330xi
Yupp, you're right about at the mark for a battery replacement. They typically last about 4-5 years in these cars.
Old 01-20-2014, 11:29 AM
Now, can I replace the battery myself without resetting the system, as there are multiple posts that state it is required while others contradict it?
Old 01-20-2014, 11:50 AM
The battery needs to be registered to the car.
Registration does the following:
1. Tells the car there is a new battery
2. Logs mileage
3. Resets charging algorithms
4. Stores a reference value around 80% capacity
You can install the battery, then take it somewhere to be registered.
Keep the same specs as your current one, Ah and CCA, and type, AGM or non-AGM. If you change Ah or battery type, you need to have the car programmed, then registered.
