Old 01-24-2014, 03:58 PM
musa's Avatar
musa musa is online now
Mein Auto: 528ia , X5 4.4 S, 335i cp
Bloody alternator died
Been having sluggish startups in the mornings last couple of weeks and then the alternator died on me two days back. It's the original at 181K miles. Battery light is on and confirmed battery is ok. I bought a replacement from starterpros for $212 with lifetime warranty. It should arrive early next week.
http://www.starterpros.com/1997-BMW-...lternator.html
I'm prepping the car over the weekend. Any recommendations while in there other than replacing the belts? The pulleys are ok- no noises.
_____________________________________
E39 528ia, E53 X5 4.4 Sports, E92 335i coupe
Old 01-24-2014, 04:05 PM
Burning2nd's Avatar
Under the lift arms
did you try to wake it up?
15486372<-----
Old 01-24-2014, 08:03 PM
helpmyfive helpmyfive is offline
Mein Auto: 528i
How is your oil filter housing seal? With all that junk out of the way, I'd consider swapping it. How is your CCV? The Alt is a fairly quick procedure. Good luck.
Old 01-25-2014, 02:54 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Common questions which need to be answered BEFORE you do an alternator and/or drive belt system overhaul:
- 1st: Physically, determine what type of tensioners you have (1)
- 2nd: Physically, determine exactly what alternator you have (1)
- 3rd: Determine which parts you need to buy for a complete drive belt system overhaul (1)
- 4th: Do the alternator and drive belt system DIY (belts, tensioners, pulleys, rollers, alternator) (1)
Alternator and Belt Drive DIYs:
- Removal instructions for the alternator & drive belt system of a 2002 525i
- Removal instructions for the fan shroud of a 2002 525i
- Alternator and Belt Drive DIY (1) (2)
- How to tell if you have spring-drive or hydraulic belt tensioners or both (1)
- How to diagnose noises coming from the drive belt system (1)
- One users' example of total electrical failure (AAA towed away) alternator repair (1) (2)
- Video of cold idle engine squeal (1)
- Recommended parts list for a complete belt drive system overhaul (1)
- How to make your own BMW special cooling & belt drive system counterhold tools (1)
Old 01-26-2014, 11:24 AM
EconoBox EconoBox is offline
Mein Auto: 2001 530i (E39) 140k
My car was on the 3rd alternator by 125k.
Old 01-26-2014, 12:28 PM
scott740il scott740il is offline
Send a message via AIM to scott740il
Mein Auto: 1999 540iT Wagon
i just replaced mine last week. 128K here.
Old 01-26-2014, 11:35 PM
musa's Avatar
The fan clutch and blade are original too. Am I playing with fire not to replace them sooner rather than later? Just musing.....
Old 01-27-2014, 05:53 AM
KKlop KKlop is offline
Mein Auto: '99 528i M52TU
Same for your vanos oil hose.
1999 528i Jet Black Sport/Premium Sedan - Dinan ECU Stage II, CAI, Scorpion Free Flow Exhaust, Rouge Pulleys, Akebono pads
Old 01-27-2014, 09:20 AM
kylesteezedknox kylesteezedknox is offline
Mein Auto: 1997 528i bmw
on my 528i I just replaced the alternator the battery went with it to, the ventilation system on the alternator for 5 series is kinda wack it sucks up leaves I even found a actual dead bee in the points of the alternator smh -_- the points were all corroded
Old 01-28-2014, 11:23 PM
overwerked1 overwerked1 is offline
Mein Auto: 2003 540i
mine took a dump recently also - of course a week after waterpump was replaced.. hindsight was 20/20. however, $260 part + install from a friend - no complaints!
Imitation is the sincerest form of flattery.
