Old 01-25-2014, 02:21 PM
david831's Avatar
david831 david831 is offline
Cuztomizing
Mein Auto: 2000 BMW 528i
Wich wire its negative and positive
Hi mates
I currently dont have a voltage tester i was wondering if you guys know wich wire its negative and wich one its positive from those 3 wires. Those wires are from the front signal light wires.
SENT FROM SAMSUNG GALAXY S3
Once a Bmw will Alwayz be a Bmw
Old 01-25-2014, 02:24 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Originally Posted by david831 View Post
Hi mates
In my experience, brown, on BMW, has often been negative.
Old 01-25-2014, 02:57 PM
White94RX White94RX is offline
Mein Auto: E39 540
Brown is always ground on a BMW.
BMW Level 1 Master Certified
2001 BMW 540i
Old 01-25-2014, 02:59 PM
david831's Avatar
Cuztomizing
Thanks mates! Wich one will the positive be?
Old 01-25-2014, 04:04 PM
JimLev JimLev is offline
Mein Auto: 540/6, Tribeca
Both of the other are positive, one should be for the directional bulb and the other for the parking light.
The bulb in that socket should have 2 filaments in it.
Old 01-25-2014, 04:23 PM
david831's Avatar
Cuztomizing
Thanks for the reply jimlev
Wich one send 12v cleanly to use to connect the halos?
Old 01-25-2014, 04:58 PM
JDeGraff89's Avatar
JDeGraff89 JDeGraff89 is offline
Otto Zwei-Punkt-Null
Mein Auto: 12- 2002 530i Auto,
Its the green and white one for the DLR right?.. Don't take this as. An answer to your question. But I think you wanna tap the green and white For the halos.
Old 01-25-2014, 05:01 PM
david831's Avatar
Cuztomizing
JDeGraff89,
I got no idea but i would like my halos to be DLR...I need one negative wich is the "BrowN" wire ...Now i need a positive from the same connection to tap it to the positive wire from halos.
Old 01-25-2014, 05:03 PM
JDeGraff89's Avatar
I'm looking into it right now. But google isn't giving me any clear cut paths
Old 01-25-2014, 05:12 PM
JDeGraff89's Avatar
Ok so.. Do you have the self splicing wire clamp things? They cut the insulation and tap into the wire. If you are using these I would be able to recommend trial and error. Because you can remove them and just cover the insulation with either heat shrink or electrical tape.
david831's Avatar
Cuztomizing
Yeah i agree with u on google.
Old 01-25-2014, 05:21 PM
david831's Avatar
Cuztomizing
Jdegraff89
Yes those are the wire crimping connectors ill be using for the install.
Old 01-25-2014, 05:24 PM
JDeGraff89's Avatar
Ok.. Trial and error man. And please report back with the answer. Again my hunch is the green and white but I am not 100% certain. But those connectors only make a thin slice and shouldn't cause massive damage if you were to remove them.
Old 01-25-2014, 05:59 PM
Mein Auto: E39 540
Any do it yourselfer needs a multi meter. Even a cheap one will do what you need it to.
2001 BMW 540i
Old 01-25-2014, 07:03 PM
david831's Avatar
Cuztomizing
What size of gauge wire you guys recommend for this istallation?
Old 01-26-2014, 01:40 PM
david831's Avatar
Cuztomizing
Wheres the safest place to power relay
Sup mates
As you can see im trying to power some halo lights . I would like to connect a relay so i can add an on and off switch . Do any have a wiring diagram that shows me how to wire them? Any help its greatly appreciated.
Old 01-26-2014, 11:36 PM
bluebee's Avatar
I typed /angel eye f3 in the bestlinks, and this came up quicker than it took me to type this and cut and paste it for you ...
- How to remove angel eye bulbs (1) (2) (3) how to retrofit halogen angeleye bulb to LEDs (1) (2) (3) (4) how to modify pre-facelift headlights to angel eyes (1) (2) (3) (4) & which stock angel-eye bulbs to buy (1) (2) (3)
EDIT:
Without a $20 DMM, you're wasting OUR time ... and yours. So, I'll put the OP on iggy until a DMM shows up at his doorstep...
See also:
- Common tools needed for the E39 & an obdii DTC scanner & an SRS reset tool & accurate measurement tools & specialty cooling system tools
