Old 01-25-2014, 09:12 PM
yyj3869 yyj3869 is offline
Mein Auto: 2011 e92 328i coupe
Is this normal?
hi,
I'm first time bimmer owner. currently i purchased 2011 cpo 328i coupe only hits 12k.
while i drove 15-20 miles and noticed that oil temperature gauge strangely move around 250 and little go down and up but i doesn't go over 250 which will be overheated. is this normal?
I used to drive mini cooper and vw cc and i haven't experienced such thing.
one more thing i noticed that was idle problem. while car is parked and turn steering wheel little and rpm goes little down and back to normal. i saw some more situation regarding idle problem while i was driving. I don't know if it's normal or not.. i need you guys opinion.
i do have 3 years extended free maintenance. do i have to get service?
Old 01-25-2014, 09:18 PM
Miller335 Miller335 is offline
Mein Auto: 2007 E92
Sounds like everything is fine to me.
250 on the oil is fine.
Turning your wheel at idle puts load on the engine so a slightly dipping idle would be normal.
Old 01-25-2014, 10:22 PM
Smalls1000's Avatar
Smalls1000 Smalls1000 is offline
Mein Auto: 2007 BMW 335i
Agreed, your power steering pump is ran off the engine via belt.
Old 01-26-2014, 04:57 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Originally Posted by yyj3869 View Post
hi,
Normal.
Nervous?
Old 01-26-2014, 07:31 AM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
Too much information
None of my cars have an oil temp gauge ..... problem solved.
Oh, and never turn your steering wheel unless the car is rolling forward or in reverse ......saves wear on the tires and strain on the ps.
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
(Hey Jim... am I diversified?)
Old 01-26-2014, 08:43 AM
Banned
Mein Auto: 2007-335 HTC
if you are worried Burger motorsports sells lower temp oil thermostats and its easy to replace
I took the spring out and heated up about 3 coils with my torch till red hot, let it cool and put it back in and the temp runs about 10 degrees lower now
