Old 01-26-2014, 01:05 AM
Mr-Ben Mr-Ben is offline
Mein Auto: E90
Cabin Temerature Sensors
Can anyone tell me where the connectors go from the wiring harness at the back of the glovebox?
I took out the glovebox to replace blower motor - that was a sucess, only I have come to put everything back together and I can NOT find where 2 wires/connectors go ? One is white about 12mm wide the other if black and about 6mm wide. They come from the same wire loom as the glovebox light connector, torch charger, footwell light.
My heating shuts down when I turn up the temperature on the passenger side of the cabin so I am guessing that one connector should plug into a temperature sensor ?.....perhaps both should ?
I am wondering if one/both sensors have fallen off the back of glove box and thats why I can not find them.....what do they look like ?
any ideas ? .....a diagram would be great
Old 01-28-2014, 02:52 PM
Mein Auto: E90
Question
Anyone ?
Old 01-28-2014, 06:34 PM
Mein Auto: '06 AW 330xi
You can try
http://www.bmw-planet.com/diagrams/r.../e90/index.htm
Or
realoem.com, but I doubt this will help. This us for part look up
glove box wiring loom.
