Old 01-26-2014, 01:52 PM
DarkxStar DarkxStar is offline
Mein Auto: BMW 528i (E39)
Check Fluids 528i e39
can anyone show me pictures or tell me where on the engine is where i can put power steering , coolant, water, transmission, and brake fluids? i have a BMW 528i E39 if you must ask. Please help me thank you
Old 01-26-2014, 11:33 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Why not just type /fluid f3 in the bestlinks?
I just did - and this came up in a split second:
- BMW E39 fluid summary printout for your glovebox (1)
There's a thread for every fluid in that one link... so you're covered for every fluid there is, namely ...
- Motor oil: BMW approved motor oils (pdf) & tribal motor oil recommendations (1) (2) (3) & gravity oil change DIY (1) (2) (3) (4) (5) & vacuum extraction DIY (1) (2) (3) & drill pump DIY (1)
- Gasoline: Engine fuel & octane (1) & "The Gasoline FAQ" & top-tier gas stations (1) & Techron additives (1) & how to clean your gas gauge sending unit (1) & mpg calculations (1) how large is the fuel tank and reserve in the E39 (1) & what gasoline to use (1) & how much gas should be left to cool the fuel pump (1) & how to siphon the fuel out of the tank (1) & what is the cost differential between 87 & 91 octane AKI (1)
- MTF: Manual transmission fluid (1) (2) & manual transmission fluid-change DIYs (1) (2) (3)
- ATF: Automatic transmission fluid (1) (2) (3) (4) & automatic transmission fluid & filter DIYs (1) (2) (3) (4) (5) & torque values (1) & how to find the hidden E39 transmission fluid level dipstick (1) & why ATF gushes out of the fill hole (1) & ZF 5HP19 facts (1)
- PSF: Power steering fluid (1) (2) & power steering fluid flush DIYs (1) (2) (3) (4) & volumes (1)
- Coolant: Coolant, for engine, automatic transmission, power steering, and AC evaporator cooling (1) & bleeding (1) (2) (3) or refilling DIYs (1)
- Brake & clutch fluid: Brake & clutch hydraulic fluid (1) & recommended E39 brake job "fluids" (1) & how brake bleeding DIYs (1) (2) (3) (4) (5)
- A/C: Air conditioner refrigerant & PAG oil (1) & how to refill your A/C system (1) (2) (3) (4) & what to use to rid yourself of the BMW gym sock stink (1)
- Differential: Rear differential hypoid gear oil (1) & differential fluid change DIYs (1) (2) (3)
- Battery: What battery (1) & what battery maintenance (1) & battery electrolyte (1) & battery replacement DIY (1) (2) (3) & how NOT to change the battery (1) (2) (3)
- Windshield fluid: Windshield washer fluid (1)
- Intensive cleaner: Intensive cleaning system fluid (1)
- Windows: Window glass cleaner fluids & cloths for the inside window & windshield glass (1)
- Tire air: Recommended tire pressures (1) (2) (3) & the claimed benefits of nitrogen gas (1) (2)
- Wheels: Best product for cleaning wheels (1)
- Interior: Interior cockpit & dashboard cleaners (1)
- Carpets: Suggested carpet cleaners (1)
- Floormats: Suggested floor mat cleaning & shampooing (1)
- Headliner: Solvent for cleaning the headliner fabric (1)
- Vapor barriers: Sealant for door panel vapor barriers (1) & sizes for the adhesive (1)
- Engine cleaner: External engine degreaser, engine bay cleaning & engine compartment detailing (1) (2) (3) (4) (5) (6) (7) (8)
- BMW list of lubricants, sealants, & thread lockers (pdf) (shrunk gif) (original-size jpg)
- Fundamental BMW decision-making religious camps (1) & motor oil Petrolism (1), coolant decisions (1), & gasoline dogma (1)
