Old 01-26-2014, 01:40 PM
sentrex sentrex is offline
Mein Auto: 645ci convertible 2004
2 errors within DME
i re scan the car this morning and got these 2 errors
DME 29a8 power management vehicle electrical system closed circuit,fault current
DME 27a0 DME fan,electrical box open circuit
and
AFS 614aal motor position angle not initialized
Old 01-26-2014, 03:16 PM
rebel.ranter rebel.ranter is offline
Mein Auto: M6, 630i, 320iC
27a0:
http://www.bimmerfest.com/forums/sho...d.php?t=475791
http://forums.pelicanparts.com/bmw-z...n-control.html
29a8:
http://www.justanswer.com/bmw/6p7qi-...min-45-00.html
Old 01-26-2014, 03:44 PM
HerbP HerbP is offline
and
I still think that you have fuse or possibly a bad connection somewhere. The AFS will clear itself after running the reset. Crank the car 3 times each direction with the steering wheel to a complete stop, remove the key & open the drivers door.
There are just to many things going on with the DME circuit. Don't I remember you replacing the IVM? If so, was it not in the fuse panel under the hood? It is possible that a fuse is not seated all of the way, or corrsion from years of service. There have also been reports of water getting in that panel, if the fresh air drains are not cleaned on each of the front fenders.
I was pretty sure last night there wwould be something going on. I am going to ask one last question, have you charged the battery recently?
Old 01-26-2014, 03:45 PM
Thanks rebel the post for the fan is a 7 series would you know where this fan is and looks like on the 645??
Old 01-26-2014, 04:24 PM
Well DIS is pretty cool i went further in diagnostics and was able to test the e box fan test was unsuccessful the DIS sais to replace e box fan part #m6506 e box fan,now what do i need to see the schematics so i can see where this part is located is it in the wds program?
Old 01-26-2014, 04:26 PM
There is a test in DIS to test the fan for operation. There are either 3 or 4 speeds that the fan will be tested at. There is a relay on the fan to the far left top side of the radiator. I suggest running the test to see what it shows.
Good Luck!
Old 01-26-2014, 04:42 PM
actually you might be on something cause i do have an error about active steering i will open the garage door tomorrow and let her run and do those tests
Yes i constantly have it on a trickle charger i will pull all fuses tomorrow and make sure they are all seated well in the trunk and in the glove box,do you know where this e box fan is located i will check connections there as well
This beats watching tv at least i'll get to know my car
Old 01-26-2014, 04:56 PM
Did the fan come on at all?
Old 01-26-2014, 05:06 PM
no ran the test with dis and the fan didn't come on at all dis tells me to replace it but i would like to see if i'm getting voltage to it if i can find it
Old 01-26-2014, 05:22 PM
Here is the PDF for the Ebox fan. It will show you where the main fuse panel is, & how to remove. Disregard my other reply concerning the cooling fan. While I was searching the WDS system, I found the wiring for the Ebox fan. I learn something everyday about theses cars. I still suspect you might find a blown fuse before you get to the fan. I will attach the fuse number shortly.
Have you tried install Firefox on your PC to see if it will run WDS? Just be careful if you install it, to not install other junk software you might not want!
http://www.mozilla.com/
File Type: pdf RA Replacing fan for electronics box (N62, N62TU).pdf (78.1 KB, 177 views)
Old 01-26-2014, 05:26 PM
i will try firefox right now
thanks
Old 01-26-2014, 06:46 PM
did you find this in tis or wds the instructions with the pictures??
Old 01-26-2014, 06:58 PM
That was in TIS under the electrical system.
Old 01-28-2014, 04:42 PM
Well after trouble shooting my ebox fan error,taking apart the wiring harness i found a hole bunch of more fuses,i tested them they are all good i took the e box fan and applied 12 volts to it and nothing so i think i found that issue,here is a pix of the fuses in the dme box
Old 01-29-2014, 05:14 PM
I did a Google, & it seems that there is a thread where some people have used a motor from Radio Shack in theirs. a 5.00 fix. I still think that something else is also related to your problem? I have crashed my new PC, & have been quite occupied trying to recover it. This is what happens when you download some bad software.
Old 01-29-2014, 05:26 PM
I found one on ebay for $25.00 at least that will be fixed will keep digging will re scan after good luck on your pc
Old 01-29-2014, 05:49 PM
That sounds good. I now have Microsoft on the phone.
