Old 01-26-2014, 04:02 PM
BigDog6469 BigDog6469 is offline
Mein Auto: 2011 328i
Need Help DRL
I am new to the site and my BMW I have a 2011 328i sedan with idrive with the Halogan lights with the Angel Eyes or Corona Rings the stock look on them from the factory is a yellowish color so I just installed the Weisslicht kit for it the ultra bright white which makes them look like the newer models my question is and I have tried everything is there anyway of making the Halo Rings now my Day Time Running lights with out the low beams on? if I turn my headlight switch to position 2 parking lights they come on but so do my side lights too and if I turn the DRL from my idrive the low beams is just on any help in the matter would be thankful.
Old 01-30-2014, 02:15 PM
E92-Lighting's Avatar
Mein Auto: 335i
you will need a special harness to have your angel eyes as your DRL.
BMW ACCESSORIES and PARTS
Old 01-30-2014, 02:44 PM
Mein Auto: '06 AW 330xi
You don't need a harness. You can have the car coded to have the AE only as DRL.
Check the coding section
