Old 01-27-2014, 02:32 AM
fairylightguy fairylightguy is offline
Mein Auto: bmw540i
Window washers
Can anyone give me a link to see a plan on how these are set up.i have a 2002 e39 5401
My washers have stopped working and it looks like a pump is broken
Old 01-27-2014, 03:03 AM
degetzel degetzel is offline
Mein Auto: 2003 525i
Check under 'Vehicle electrical system'. This is the link for my car. It should be the same for yours.
http://bmwfans.info/parts-catalog/E3...ing_container/
I also had a problem with the washers. Low pressure and leak - was getting the low fluid error soon after toping it up.
Turned out it was a leak from the hoses.
Good luck sorting yours out!
Old 01-27-2014, 05:06 AM
mr magoo's Avatar
mr magoo mr magoo is offline
Mein Auto: 2000 528i
can you hear it
Turn the key on and press the pump lever to see if you can hear it.
When I did this, I noticed a split hose.
Old 01-29-2014, 05:48 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
See also:
- What windshield washer fluid to use (1) (2) & what intensive cleaning system fluid to use (1) & how to adjust windshield washer spray nozzles (1) & where to get OEM VDO/Conti windshield washer pumps (1) (2) & windshield washer reservoir & pump DIYs (1) (2) (3) & specific issues of windshield reservoirs prone to leaking due to an ill-fitting pump o-ring gasket (1) (2) or to hose disintegration (1) (2) or to leaks in the main reservoir (1) (2) (3) or leaks in the intensive wash system (1) (2) or the pump itself goes bad (1) (2) & further debugging hints (1) & one users windshield washer leak experience (1)
