Old 01-27-2014, 07:57 AM
10yrowner 10yrowner is offline
Mein Auto: X3 2007
Gas mileage dismal
Gentlemen,
just purchased a 2011 328I x drive. still under warranty. had it in dealer and they said they "reset" the computer for mileage or fuel consumption. unfortunately it is once again at dismal fuel mileage. I have placed the car in neutral on a long hill to see if it will "freewheel" to test engine braking. it wasn't much of a change. checked e-brake of course...run flat tires. is this normal for this model? I can't believe it is. any ideas are welcome. going back into service in a month or so for the total service. just had it in under re-call on the battery cable through fire wall. rear defrost now out.
Old 01-27-2014, 08:01 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Define "dismal".
My 2009 335 xDrive gets 30 - 32 mpg at >70 mph on the highway. It gets in the low 20s in the city. I think that's pretty good.
Old 01-27-2014, 08:09 AM
BashedBarrique's Avatar
BashedBarrique BashedBarrique is online now
Mein Auto: 2006 325i
Originally Posted by Zooks527 View Post
Define "dismal".
My 2006 325i also gets 30 -32 mpg highway and around 23 -25 city. I think that's pretty good for a 3200 lb car with a 3.0 liter engine, especially since I drive it aggressively.
For comparison our 2010 Corolla with a 1.8 liter 4 cyl gets 38-40 highway and 28-30 city, and it's a wheezy little slow poke compare to the BMW.
Old 01-27-2014, 10:29 AM
floydarogers's Avatar
Pedant and Curmudgeon
Originally Posted by 10yrowner View Post
... I have placed the car in neutral on a long hill to see if it will "freewheel" to test engine braking. it wasn't much of a change. ...
You will get better mileage leaving it in gear when going down hills. The ECU is able to completely cut fuel supply to the injectors when coasting, but if you're in neutral it has to use some to keep the engine idling.
You don't say what your mileage is, but 15-20 mpg is not unusual for a city car.
Old 01-27-2014, 10:46 AM
I should add that my "city" figure is actually for suburban driving that includes some brief four lane highway runs of a few miles or longer. Still I think 23-25 mpg is pretty good.
Old 01-27-2014, 10:53 AM
ptrcd003 ptrcd003 is offline
Mein Auto: 328i LCI
Around 15 MPG city is normal, especially if you're X-drive. Of course, I mean stop and go traffic city driving, not suburban. What kind of mileage are you getting?
