Old 01-28-2014, 11:50 AM
invest4you invest4you is offline
Mein Auto: 2011 750Li
Performance Upgrade for 2011 750li?
Hey everyone, now that I have the exterior of my vehicle looking the way I want. I looking for some advice on a performance upgrade. Can someone suggest a simple (hopefully plug and play) performance upgrade that will give the most bang for your buck. I really don't feel like this car needs a lot, but it would be nice to find something cost efficient that will provide a noticeable difference. Also I don't want to have to send the ecu somewhere or be without the car for an extended period of time.
Look forward to your advice. Thanks
Old 01-28-2014, 12:04 PM
SLS-BMW's Avatar
SLS-BMW SLS-BMW is offline
Mein Auto: F01 750i
I have not done either yet but BMS Stage 1 and a PedalBox should do the trick! All can be self installed and will cost you less than $700.
Read the "Dinan Scum" Thread and you will find out a lot.
Old 01-28-2014, 03:52 PM
Snorlax Snorlax is offline
Mein Auto: _
BMS Stage 1 & Pedalbox. Done.
Old 01-28-2014, 04:25 PM
Thank you. Any suggestions on where to buy both?
Old 01-28-2014, 05:20 PM
Mein Auto: _
BMS: www.burgertuning.com
Pedalbox: www.motivemods.com
Old 02-03-2014, 07:01 AM
Thank you. I ordered mine on Friday, will let you know how I like it.
Old 02-05-2014, 11:29 AM
Raj, I installed the stage 1 last night. I haven't had much time to drive, but I really can't say that I notice much of a difference. Hopefully the more time I'm in the car, the more I will notice it. Also it's 0 degrees here, so it doesn't make it much fun to drive. Any thoughts? Thanks
Old 02-06-2014, 04:37 PM
CABimmerNation's Avatar
CABimmerNation CABimmerNation is offline
CABimmerNation
Mein Auto: 2010 750i M Sport
If you can't feel anything, it's definitely not installed correctly. Oh wait, you said bms, I'm sorry, I thought you were talking about Dinan. Yeah, you really don't feel any difference with the bms, sorry.
Dinan S3, PedalBox, 22" Agetro rims, H&R spt springs, RDsport front lip, coded, paddle shift retrofit, AlpineMSS HID 8000k. All exterior chrome, roof, roof spoiler and everything behind wheels painted black, wing, side and rear reflectors and door handle trim painted white, light smoke on tail lights. Audio: focal separates, earthquake low profile subs under front seats (crossed over as mid base to support the pathetic 4" fronts), arc audio amps, audiocontrol lcq-1 and epicenter, (2) L7 subs.
Old 02-06-2014, 05:35 PM
DLF750's Avatar
DLF750 DLF750 is offline
Mein Auto: 2013 Audi A8L
invest, let me know if you end up liking the BMS and how easy was it to install? I'm semi considering this as well. I was thinking pedalbox but honestly, i don't like the controller box gizmo sitting out in the cabin.
GONE (but not forgotten): 2011 BMW F01 750i. Dark grey, black interior. Anthracite headliner, M Package, 760 Quad Tips/Diffuser, PedalBox, Sport Package and a bunch of other stuff...
Old 02-06-2014, 05:50 PM
CABimmerNation
20 minute install and its hidden in the ash tray. Follow aom7 step by step guide, it's simple. Turned mine off last night for the first time, before giving the car to a valet, and it felt like I was stuck in mud. You really want an ecu tune and pedalbox, but if you could only have one, pedalbox is the way to go.
Old 02-06-2014, 05:54 PM
Mein Auto: _
Agreed. When I turn it off, I want to kick the car to get it moving. Amazing change.
Old 02-06-2014, 06:10 PM
The more I drive it the more I think I like it. I agree with both of you and ordered a pedal box today. I think the combination of both will be a nice addition. Will keep you posted. Thanks for the advice.
Old 02-06-2014, 06:16 PM
DLF, the install on the BMS was relatively easy. Probably took 30 minutes. The car feels really quick while rolling, but stills has that lag where I think the pedal box will really help.
Old 02-06-2014, 06:25 PM
AdamG13 AdamG13 is offline
Mein Auto: 2016 740Li
Though the N63 tune works on the 09's thru present 750s, BMS also has an N63tu tune now. Since I lagged on placing my order I guess I'm going to get that one. It's listed for the '14 550 but they said they're going to update it so that buyers know it works on the 13+ 650/750's too.
Sent my pedalbox back today. Mine was having some issues and was causing the car to have small sporadic accelerations when at idle. Didn't like the way it felt during city driving anyway and usually had to turn it off unless I was on the highway. Guess I'll just get used to pushing the accelerator farther down.
2016 740i Singapore Grey
2014 M6 Citrin Black
2013 750i Mineral White
2011 750i Jet Black
2007 750i Monaco Blue
Old 02-06-2014, 06:41 PM
Mein Auto: _
Sorry to hear that about your pedal box man. I just got some amazing 0-60 times with my old BMS and pedalbox. I'm getting the new BMS likely next week or the following. If all works out I should be in the 4.1-4.2 sec 0-60 range then.
Old 02-06-2014, 06:47 PM
PREDATOR 007's Avatar
PREDATOR 007 PREDATOR 007 is offline
Mein Auto: 2016 ///M5
Mine is hidden in my ashtray.
I have the "new" Stage 1 installed on my car and as soon as the weather breaks, I will be back at the track. As you may recall, I have documented Dinan and BMS and so far, neither has done much.
** Removed ** 19,000th, 22,000th, 22,222th, 26,000th, 35,000th, 45,000th 48,000th, 63,000th, Honorary 87,000th and 93,000 post in delete pls
WR 12.50 @ 112.05 MPH 9/18/14
Old 02-06-2014, 09:24 PM
Definitely getting that wood on my next car. Really looks good in contrast to the black interior. Ended up with ash grey on my last two 7's which I like, but doesn't really stand out much against all of the black leather.
I wouldn't think the PedalBox would actually have an affect on the 0-60 time, since it'd really just be the difference in time it'd take for you foot to hit the normal full-throttle position (the floor board) as compared to whatever pedal position the pedalbox remaps full-throttle to. I'd think this would be fairly insignificant?
2011 750i Jet Black
Old 02-06-2014, 11:09 PM
Raj & richard - was there some kind of problem with your previous bms tunes? Saw on deletme thread that you had sent yours back.
2011 750i Jet Black
Old 02-07-2014, 08:05 AM
DLF750's Avatar
Thanks guys. I'll look for those install instructions, not sure I can dismantle anything in the car to get the thing to run into the ashtray. And if I did, where oh where would i put my change holder? huh? didn't think about that didya?
DLF750's Avatar
Old 02-07-2014, 08:17 AM
DLF750's Avatar
saw the install instructions, just not sure how EASY it is to remove that center console...anyone have MORE details?
Old 02-07-2014, 08:50 AM
CABimmerNation
It's ridiculously easy, just follow his instruction.
Old 02-07-2014, 08:53 AM
CABimmerNation
Never have done it before should take you 20-30 minutes. If you have done it before, you could take it apart, install the pedalbox and put it back together in under 5 minutes.
Old 02-07-2014, 09:45 AM
DLF750's Avatar
I'll muck it up for sure.
Old 02-19-2014, 11:18 AM
I recently received the error "engine malfunction" and the car went into reduced power mode. This only happened when the car was on reserve fuel. Does anyone know if this was due to the stage 1 tuner obviously increasing the fuel rate? The warning went away after I fueled up?
