Old 01-28-2014, 03:03 PM
tr0pe tr0pe is offline
Mein Auto: 2007 335i Sedan
Smile 2007 335i need Headlight suggestions
Hey all.
I'm really new to the BMW scene as I just purchased this car used about a year ago.
It's been working pretty well other than an engine problem I had (promptly fixed)
But now one of my headlights broke, and I don't want to bring it to the dealer to replace..
Essentially I'm looking to just buy a new set of headlights, preferably the better looking LED or Xenons than what I have (mine are dim and yellowish light eugh) also mine right now have the ugly yellow reflectors on the housings which is why I'll probably just buy entire new head sets.
My question is: Do I need to know what configuration of headlight I currently have in order to find a proper replacement? I keep seeing all these terms thrown around about modding them to get them to fit right and I'm totally confused.. If so, how can I figure out what type of headlights my car currently has so that I can find compatible replacements??
And once I do that, can you guys suggest me some good headlights that look nice & sleek and won't break my wallet? (Looking to spend under $600 for the set. I see sets online for $300 but I've heard they're shoddy quality etc.)
I was looking at something from maybe Spyder Auto like this http://www.spyderauto.com/product.ph...w-H7-(Included)
Thoughts?
P.S. I'm also interested in replacing the taillights on my car as I find the old fashioned pre-lci tails extremely UGLY. I was recommended to buy these lights on another forum and think they look amazing, but does anyone have experience with this company or other thoughts? http://www.thespeedline.us/servlet/t...-Series/Detail_a_
Old 01-28-2014, 10:47 PM
wilt wilt is online now
Mein Auto: 2011 328i
HID source in a housing intended for halogen bulbs is absolutely wrong...the light is not properly controlled for cutoff to prevent blinding oncoming traffic, it is not a street legal combination. HID need a proper projection system (a lens), and a self-leveling system.
Don't bother with blue halogen bulbs...you will find tons of reports of poor visibility in rain/snow/fog.
Don't bother with higher wattage bulbs (I have only read that Osram 65W will work) as excess heat can melt/damage the headlight housing, and the wiring harness was not designed to pass the wattage demanded by 100W bulbs
And most 'brighter' 55W bulbs burn out fairly rapidly, compared to standard OEM halogens provided in the car from the factory. The biggest beef that folks have with Sylvania Superstar Ultras is short life.
Old 01-29-2014, 08:15 PM
okay thanks for the info.
Can you recommend a replacement housing then? Like the entire headlight assembly (I want a plug and play fix for this)
I was looking at Umnitza's headlight kits like this http://www.umnitza.com/projector90-w...ir-p-1167.html
Total with bulbs included would be in the upper $500 range which isn't too bad
Anyone have experience with Umnitza or can recommend other brands?
Old 01-30-2014, 03:04 PM
E92-Lighting's Avatar
Mein Auto: 335i
we have your replacement halogen bulbs which are H7 at 55Watts, its all error free
http://www.e92-lighting.com/mtec-bul...7-super-white/
BMW ACCESSORIES and PARTS
Old 01-30-2014, 06:03 PM
umnitza's Avatar
umnitza umnitza is offline
www.umnitza.com
Mein Auto: ///M
here's a recent one we did for a customer:
https://www.facebook.com/Umnitza/pos...?stream_ref=10
Old 01-31-2014, 07:26 AM
Mein Auto: '06 AW 330xi
Don't get spyder.
I would source a set of DEPO housings from eBay and have a local shop modify them for you....ie install full LED rings, clear lens mod, etc.
The DEPO projectors are not my favorite and aren't that great in quality but it is better than the oem halogen setup.
Anyway, the reason I suggest you get a set of housings and mod them locally is because opening the headlights is a tricky process and if you have issues, you can bring it back to the shop for repair. If you buy a pre-modified set online, you have to ship your headlights back to them for repair. That will extend down time...
Old 01-31-2014, 06:37 PM
Originally Posted by fdriller9 View Post
Don't get spyder.
Yeah but I was hoping to buy a set that I wouldn't have to modify in any way.
Old 01-31-2014, 08:29 PM
machtnichts machtnichts is offline
Mein Auto: 2011 328i xdrive
Just buy a $12 bulb and there's no need to take it to the dealer. Once you have changed your own halogen bulb through that little door in the fender liner, you will have a priceless sense of accomplishment. It's tight!
I don't see what is so bad about the halogens. They were pretty normal in 2007. I would live with it and enjoy xenons in your next car.
I would check further on those taillights, I heard rumors that they didn't synch well with the computer and would cause error messages. I think only OEM, which are more like $500, are guaranteed to work.
Where I drive.
Old 01-31-2014, 09:00 PM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
Look up fishcake321 on eBay. They're around $400-500. Also search for blacklines for your rear tail lights... They'll look sportier but still not too aftermarket.
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, backline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 02-01-2014, 06:37 AM
You don't have to modify them. They are plug and play for the most part.
But if you want better led rings, they will need to be modified. Everyone that sells depos with full led rings, are modified.
Old 02-01-2014, 08:29 AM
In any street legal conversion...
  1. Projector housings have self-levelling systems
  2. HID lamps go into projector housing (with self-leveling system)
  3. Ballasts (which convert 12v to 20000v) drive HID lamps
The price of the housing kits is for #1 only (if I correctly recall the description of the contents 'HID is extra'), you still need to also get #2 and #3 before you have a working system. Factor all that together before you sink your money...you don't want to get half way into the conversion to discover the need to still spend a lot more money.
Old 02-01-2014, 11:40 AM
umnitza's Avatar
www.umnitza.com
Mein Auto: ///M
That's what we build.
Old 02-01-2014, 04:05 PM
ptrcd003 ptrcd003 is offline
Mein Auto: 328i LCI
Oh come on. MY 99 had xenons...this is just a case of BMW screwing people by making (an essential safety item IMO) an option.
Old 02-01-2014, 05:09 PM
Hey, I was psyched when I upgraded my Miata to Halogens from sealed beams. Maybe I just haven't seen Paree yet when it comes to headlights.
Where I drive.
head light, head lights, replacement lights
