cylinder head - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 01-29-2014, 08:14 PM
zenith zenith is offline
Mein Auto: 1993 325i bmw & 1994 525
cylinder head
ive taken the cylinder head off my 1994 525i and now im not sure if the oil pressure valve had a o-ring on top of it or not.could anyone please jog my memory again and tell if it does require a o-ring or not before I torque the head bolts.
thanks.
Old 01-29-2014, 10:24 PM
imae34driver imae34driver is offline
Resident e34 Racer
Mein Auto: 1995 540i SPORT /6 spd
Please be more clear..
Oil pressure switch? Or like the vanos unit? What..
Bone stock 95' 540i/6 Blk/blk w/ ram style C.A.I / JBR LWFW/ DUDMD tune/ straight pipe /545 SSK /3.15 LSD / Rev-shift motor mounts/stage 4, 6 puck clutch/ K Sport coil overs/Eibach sway bars/ VAC under drive pulleys/weight reduction /sparco 368, Recaro seats, sparco harnesses, NX wet kit, M/T E/T streets.
"Skill can only get you so far, then comes money!"
R . I . P Paul Walker - 1973 - 2013
Old 01-30-2014, 12:30 AM
sorry its the non return valve on the cylinder head
Old 01-30-2014, 08:09 AM
Resident e34 Racer
Huh? Google doesn't understand you either. So I'm thinking you don't know what it is or the correct term for it..
Now your loosely describing an OSV that i don't know for sure the m50 had..
Why don't you post a diagram and point it out.
Old 01-30-2014, 11:33 AM
m735is m735is is offline
Mein Auto: e23, e32, e34, e39
http://www.realoem.com/bmw/showparts...33&hg=11&fg=15
Number 2 in this picture. I don't see a listing for any O-ring.
Old 01-30-2014, 05:57 PM
yeah its the same diagram shown by m735is pointing out number 2.
I didn't see a o-ring but I had to make sure so thanks guys for the
help much appreciated.
Old 02-05-2014, 10:13 AM
Bugsie Bugsie is offline
Mein Auto: BMW E34 M50 2.5
Hi all,
Hopefully not late. I removed the head not so long ago and I'm pretty sure there's NO o'ring.
Cheers
Fernando
Old 02-13-2014, 11:34 PM
rookie error!!!!
Hi all,classic rookie error i suppose made by myself.
i took the cam lifters out of the tray and didnt mark or reference any to its bore.
i thought i had did the right thing by putting them all in ziplock bags but realised after the fact that i shouldnt have.
im asking if i should now buy new lifters or still use the old ones in now random bores?
i did (thank god) manage to write on the ziplock bags which ones were the exhaust and intake.
Old 02-14-2014, 12:43 AM
Resident e34 Racer
I think hydrolic lifters are ok to swap around.. They spin and expand in the bore a lot so they don't really become matched as much as solid lifters i believe..
This may be wrong! Im Not sure...
Old 02-15-2014, 05:25 PM
hey thanks imae34driver for the feed back.i spoke to a friend of mine and he said pretty much the same thing but said i might
have some problems 3-4 months down the track.
i shall research a bit more before i make any decisions as to keeping or replacing them.
Old 02-20-2014, 06:57 PM
going to purchase cams/lifters from a donor car now so i dont have any hassles later on.
got them off trade me nz for $115 plus postage.sweet.
its still a risk putting faith in online shopping but i havnt been let down yet.
