Old 02-03-2014, 05:52 PM
Nickyc Nickyc is offline
Mein Auto: 2011 328i
Anyone with this problem?
I have a 2011 328i sedan with 62k miles that has been regularly serviced at the dealer. Until now I've only had a single problem with a wheel bearing that was fixed easily and no big deal. This morning on the way to work. When I tried to accelerate aggressively it had a jerky and hesitating feeling and then finally went ahead into gear. No engine lights, no noises. It felt like it was trying to shift but was hesitating. Or possibly inadequate fuel was getting to the motor. On the way home from work I re enacted this several times. If I accelerate smoothly it has no issues, cruises on the interstate and has no problems downshifting when slowing down. It only occurs when you aggressively accelerate. It even downshifts fine when climbing the hills to our house. It seemed to do it at low and high speeds. The car was cold both times I tested this. Has anyone else had similar issues? Or ideas what this is. I'm not sure whether we are looking at a fuel system problem or a transmission problem.
Old 02-03-2014, 06:21 PM
ddeliber ddeliber is offline
Loving my d
Mein Auto: E350 & 2011 335d
This hasn't happened to me, but since you seem to be able to re-create it I suggest a test to see if it is fuel/load delivery or a slow shift. Get it going to the and before you accelerate aggressively put it in Sport mode (slide the shifter to the left from D) and down shift. That will hold the gear a bit longer plus it will eliminate the shift from the possibilities (assuming that you don't need to go from 6th to 4th). If the hesitation happens it probably is not a slow shift.
NOTE: While it is in S, you will be able to see what gear it is in (it will say M2 - M6 on the display), after manually downshifting, it will go down one. If when you hammer it, it drops again it obviously needed to shift again so you will need to re-test but start from a different speed. You really shouldn't have to be near redlining it to do this. Not sure how cold the engine is when you see this, but it really isn't good to hammer it until things warm up. cold=poor lubricity of fluids + wot = bad for the things that make it go.
Old 02-03-2014, 06:25 PM
wilt wilt is online now
Huh?! When the transmission is in sport mode, it displays 'DS', and shows M1, M2, etc. only if you have manually selected a gear!
Old 02-03-2014, 06:35 PM
Loving my d
Yep, I put them backwards, I should have said downshift and then it will tell you what gear you are in. However, for the test, it doesn't matter, the point is downshift manually to help diagnose the issue, and to look at what gear you are in to see if it downshifts again when you accelerate.
Old 02-03-2014, 09:34 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
No lights does not mean no codes....HERE
