Old 02-03-2014, 07:51 PM
Go Navy Go Navy is offline
Mein Auto: 2011 BMW 328i Sedan
Rubber Trim/Gaskets Around Doors
What do you fellow BMW addicts recommend for the rubber (?) trim around the doors, which is exposed to the sun and weather? Is ArmorAll ok? I think the owner's manual says not to use anything with silicon in it. I have no idea what's in ArmorAll. Any other suggestions?
Old 02-03-2014, 07:56 PM
Nerdboss Nerdboss is offline
Mein Auto: 2011 328i
Armor all is awful. Use gummi pfledge (pronounced goo-me flay-guh) it works wonders for rubber trim pieces.
2011 328i | Jet Black | Oyster/black Dakota | Navigation | Premium package | Sport Package | Heated seats
Old 02-03-2014, 08:14 PM
And where might I find gummi fledge? I've never seen it.
Old 02-03-2014, 08:23 PM
luigi524td luigi524td is online now
Mein Auto: '13 535xDrive; '98 Z3 2.8
Amazon has it!
My opinions are free - you'll get exactly what you pay for!
Current: 2013 535xDrive | 2013 X1 MSport | 1998 Z3 2.8
Past: 2007 530xi | 2001 740i | 1998 740i | 1994 740i | 1986 524TD
"Seek and ye shall find" ... start with your owner's manual!
Click on the MrRebates logo/link below for cash back savings at on-line stores like Tirerack!
Mr. Rebates
Old 02-03-2014, 08:42 PM
Pilgrim's Avatar
Pilgrim Pilgrim is offline
Car guy since 1968
Mein Auto: 2008 E91 328xi Sportwagon
One gent I know who works on antique windshields uses Glycerin to re-invigorate the old rubber.
I don't know about the silicone issue - I usually spray my door seals with light silicone at least once a year. I do try not to get it all over the paint.
Armorall has a lot of silicone in it - as do many, many car products and paint treatments. Silicone must be removed from paint before any repair work is done or new paint does not adhere properly.
1983 Datsun 280ZX Turbo
2000 Jeep Grand Cherokee
2008 BMW E91 328xi Sportswagon
2009 BMW E92 328ix Coupe
Old 02-03-2014, 08:58 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Indeed - silicone oil is "cheater's wax" -- often used by honest, caring purveyors of Pre Owned Vehicles to make them look like new. Nope, don't last.
Old 02-04-2014, 06:19 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Never use armor all or anything silicone based on rubber. Clean them with 1Z deep cleaner and use Krytox or Gummi, for the outside trim, same but use B303 for UV protection.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
fdriller9 fdriller9 is online now
Mein Auto: '06 AW 330xi
+1 on gummi pfledge
Don't use silicone. It will cause squeaks.
In general, you don't want to use a silicone spray any where in the car. It will make noise. It's better to use a white lithium grease or the like.
Even WD-40 is bad. It dries things out over time. Eventually, squeaks come back. If you want a lubricant to last, it's gotta be grease based, not oil.
Old 02-04-2014, 07:51 AM
Phil325i's Avatar
Phil325i Phil325i is offline
Mein Auto: 325i E92 Coupe
Only problem with using lube is that if you get it on seals anywhere near window glass, you'll have streaks up and down your windows every time you raise or lower them...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; BMS clutch stop; BMS CDV; RE g/box mounts; Saikoumichi OCC; K&N; Cyba scoops; BMW Perf Exhaust; M3 rear spoiler; M3 white dash LEDs; LED Angels; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof
Old 02-04-2014, 07:56 AM
DSXMachina's Avatar
Bimmerdex 7.4!
OP, take a look at Nordic Kat's Convertible Top Sticky. Lots of excellent transferrable advice there, and much discussion of various products.
Old 02-04-2014, 08:01 AM
So, you can use B303 Aerospace Protectant on the exterior door trim/rubber? We used the stuff on our inflatable Zodiac, exposed 24/7, and it worked great. It is widely available in slightly different versions.
Based on the advice given here so far, I won't use ArmorAll. I wonder what they smear on the tire sidewalls at the local car wash to "dress" them?
Old 02-04-2014, 08:10 AM
Thanks.....just went there....what an excellent contribution. Now that I've seen the pictures, I have to say I'm glad I don't have a convertible! While they're beautiful, they look really complicated.
Old 02-04-2014, 08:59 AM
thekurgan's Avatar
Bad Lieutenant
Crap most likely. It should be water-based, and most aren't. Adam's makes some nice tire dressing; but it's really important to clean the rubber so it's black again before.
Ilse
Bruna
BMWCCA #453648
Old 02-04-2014, 09:48 AM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
I like 303 on my boat stuff plus its a sunscreen for the exposed rubber/plastic BMW trim / molding parts.
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
(Hey Jim... am I diversified?)
Old 02-04-2014, 12:24 PM
I love 303 aerospace. It's a great rubber and vinyl UV protectant.
BUT, it squeaks! don't use it on door seals.
You're better off using baby powder over 303 aerospace on the seals.
Gummi pfledge or baby powder are the only 2 things I would use on the door seals.
Old 02-04-2014, 02:50 PM
Banned
Mein Auto: 2007-335 HTC
and the name Means "Rubber Care" In German
and get some dupont "Krytox" while you are at it,
that is great stuff on rubber
Read Kats Sticky on keeping your convertible top seals in shape at the very top of the threads, she shows both rubber care products in action
Old 02-04-2014, 08:08 PM
Gosh-a-mighty, man....yer moniker's Hot Maroon!
Is it official?
