Old 02-04-2014, 10:01 AM
SoCal Hopeless SoCal Hopeless is offline
Mein Auto: 335i
Lightbulb Lightweight Battery?
Anyone heard of/using a light-weight battery?
would be sweet to shed 25 lbs
I've heard of people using mini cooper batteries, anyone running this?
Old 02-04-2014, 11:36 AM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
Why not drive with half a tank of gas and lose 50 lbs
oh ... and your car will start
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
(Hey Jim... am I diversified?)
Old 02-04-2014, 11:47 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
BMW has engineered yourelectrical power supply for what is required by their vehicle. Not a Coulomb more is needed, and none less. Weight has been minized and optomized....would you slice that short, for a pound or two?
Old 02-04-2014, 11:58 AM
bear-avhistory's Avatar
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
Part of the battery design & placement is to help the 50/50 weight balance.
Kevin
CURRENT:
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2014 BMW 435M-Sport MPPK/MPE 8ZF
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 02-04-2014, 01:14 PM
Mein Auto: '06 AW 330xi
You're better off driving around with half a tank of gas to save weight.
Fuel averages 6lb/gallon and our fuel tank holds about 16 gallons. It's around 100 lbs with a full tank of gas.
If you're going to get a lightweight battery, I'm assuming you are looking at Braille batteries.
Braille batteries are rebranded Deka batteries. You can get the same battery for half the price....
If you live in a warm climate year around, the lightweight battery may be ok.
If you live in an area that sees cold weather, forget about it. The 21lb braille/deka is 550CCAs. That's just a little bit above half the amount of CCAs an OEM battery provides.
Unless you want to keep a battery heater and tender on the braille/deka all winter, it's not worth it.
25lbs in weight savings may help in time trial, but for a street vehicle? The cons severely outweigh the benefits.
Old 02-04-2014, 01:40 PM
Mein Auto: 335i
Wow always figured gas weighed the same as water, but you're right. Thanks
