Old 02-04-2014, 12:35 PM
RacingFire RacingFire is offline
Mein Auto: 328XI
328XI 2007 help!
Hi guys, i have a little problem with my BMW and i'm sure someone here can be helping me
Last friday when i came back home, i run on the high way on cruze controle and (ABS) 4X4 light happen in my dash. So this one remove my cruze, DTC and ABS.
When i stop and start again my cars, now i have new light open ! Now i see 4x4! DTC remove and check engin.
So i scan my car with a OBD2 and i saw P1774. I call my dealor who said ' sorry that was not a BMW code i can't helping you'
I Make son search on internet and i found problem with DSC hydraulic Pump that look like to be the same problem like me, but i ask you guys if you know this trouble.
Old 02-04-2014, 12:46 PM
Mein Auto: '06 AW 330xi
If it's the pump, you can buy a used unit and separate the pump from the control unit and swap the pump onto your control unit.
If it's the control unit, you have to get a replacement (either new or used) and code it to the vehicle. Find someone who can code a used module before buying one. Not everyone can and dealerships rarely do coding on used parts. Especially a part that controls safety systems.
If you get your car scanned with a BMW specific scan tool, the DME will most likely have a specific fault stored for either the pump or control unit. This will tell you which is bad and you can go from there.
Old 02-04-2014, 12:56 PM
Mein Auto: 328XI
Thanks fdriller9,
That was exactly that kind on answer i think to find here.
Now i have a other question for us.
How i can test if it my pump problem or my control unit?
