Old 02-06-2014, 08:57 AM
birdman15 birdman15 is offline
new to BMW life
Mein Auto: 2008 328xi
2008 328xi front wheel bearings
gonna swap them out as they are starting to make a growl noise, not sure what side but they both are going. Are they just press in bearings or a whole hub assy? for those that have changed them is it a DIY project or suggest have it done at a mechanic or stealership ?
if anyone has any pics that would be super. this is our 1st BMW if it was a Jeep I'm all in and doing it myself, as I have been doing stuff liek this on my Jeep for years, bearing hub assy's , axles, drive shafts, brakes ect....
easy job yes or no?
any links anyone can post for step by step instructions
thank-you in advance
cheers
Old 02-06-2014, 09:23 AM
Watchme Watchme is offline
Mein Auto: 2011 328i E90
http://www.pelicanparts.com/BMW/tech...eplacement.htm
http://www.e90post.com/forums/showthread.php?t=870124
or google.
Old 02-06-2014, 09:34 AM
new to BMW life
so it is a bearing ONLY replacement even on the xi version? from what I was reading there or am I wrong. one link says bearing only and the other link says hub assy
this is great info thank-you very much
Old 02-06-2014, 10:51 AM
Mein Auto: '06 AW 330xi
The i models have front bearings that are bolted in.
The xi or xDrive models are pressed into the knuckle like the rears.
I wouldn't call this a DIY.
Aside from a puller and press, you may run into the problem of the outer race being rusted into the knuckle. Quite common on this chassis, especially the rears.
I had to replace the whole knuckle on my 330xi when my driver's side, rear wheel bearing was failing because the outer race was so badly rusted in the knuckle.
Old 02-06-2014, 10:55 AM
new to BMW life
cheers.
drop it at the shop to get it fixed then. beside to effin' cold outside right now.
I got bearings though one of my suppliers that have a lifetime warranty, paid a bit extra for them but hey never have to buy them again.
thnx guys
Banned
Mein Auto: 2007-335 HTC
I think all are hubs assembles now
Old 02-06-2014, 10:57 AM
Banned
or not
Old 02-06-2014, 12:02 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
easy job yes or no?
cheers
Both bearings going at once? Are you sure it's the bearings and not worn tire noise that can sometimes be mistaken for bad bearings?
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 02-06-2014, 12:21 PM
I don't think it's a big deal from the e90 post DIY.
If you don't have a press, take the whole knuckle to a shop they'll be happy to swap the bearing for you for a 20-30.
Old 02-07-2014, 06:02 AM
new to BMW life
I did think that but came to the conclusion the bearings...
