Old 02-06-2014, 03:10 PM
CaptaineNemo CaptaineNemo is offline
Mein Auto: X1 2013
Metal thingy Dropped Deep into Lighter Socket
Hi,
I accidentally dropped a tiny piece of metal thingy into the lighter socket;
While I tried to remove it, it fell even deeper into the dark gap/hole as indicated by the red arrow below:
What's down below that (hole of the) lighter socket? Since that thing I dropped is a metal piece, would it potentially cause short circuit?
Alex
Old 02-06-2014, 03:28 PM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
I'd pull the fuse, then fish around with a pick-up or hemostat. Best to remove that soonest.
Old 02-06-2014, 08:31 PM
kkingmd kkingmd is offline
Mein Auto: 2001.5 VW Passat
Agree. I've done the same thing and eventually it will short the socket and blow the fuse.
Old 02-06-2014, 08:42 PM
stonex1's Avatar
stonex1 stonex1 is offline
Mein Auto: 13' X1 35i
A quick tip is to grab your finest thin flat blade long screw driver, and rub it
on the back of the biggest speaker you have.
This will magnetize it.
Then go in and try to pull it out if you can.
From your pic, it looks like you might be okay if it doesn't cause
a connection from + to -.
2013 X1
MinGrey,Xenon,HK,PwrSeats,Sirius,XLine,Nav
Old 02-07-2014, 05:34 AM
Gort Gort is offline
Mein Auto: 2017 X3-35i xDrive
Any hardware or big box store should have a magnetic retrieval tool. The nice thing vs. a magnetic screwdriver is that the tool itself can't accidentally cause a short because the magnet is encased in a plastic rod.
Old 02-07-2014, 08:40 AM
Cool tip, thanks!!
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
