Old 02-06-2014, 11:22 PM
Smalls1000's Avatar
Smalls1000 Smalls1000 is offline
Mein Auto: 2007 BMW 335i
Question Oil in intake manifold
I've heard of the issue where people get oil in their intake manifold, but I know you shouldn't get oil in there. The closest I've ever had to an issue like this is oil getting into a cdr valve on a diesel engine. Can anyone explain how oil gets into your intake manifold and why?
Old 02-06-2014, 11:40 PM
CitizenOfDreams CitizenOfDreams is offline
Mein Auto: 1998 BMW 740i
The gases from the engine crankcase are intentionally sucked into the intake (read about positive crankcase ventilation). Those gases contain small droplets of oil. The oil is separated and returned back into the crankcase, but some amount still makes it all the way into the intake manifold. When the oil separating device goes bad, the situation worsens.
Old 02-07-2014, 03:04 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
As well, turbo can leak oil.
Old 02-07-2014, 05:39 AM
Phil325i's Avatar
Phil325i Phil325i is offline
Mein Auto: 325i E92 Coupe
Plumb in an oil catch tank.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; BMS clutch stop; BMS CDV; RE g/box mounts; Saikoumichi OCC; K&N; Cyba scoops; BMW Perf Exhaust; M3 rear spoiler; M3 white dash LEDs; LED Angels; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof
Old 02-07-2014, 08:03 AM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
Some oil is normal. A small amount of oil gets past the turbo seals and a small amount of oil goes a long way.
Old 02-07-2014, 08:54 AM
bear-avhistory's Avatar
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
An OCC is worth the time & effort to install. Will help extend the clean the valves interval.
Kevin
CURRENT:
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2014 BMW 435M-Sport MPPK/MPE 8ZF
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 02-07-2014, 01:22 PM
Smalls1000's Avatar
I think I'll get one of these oil catch cans then
Old 02-07-2014, 01:35 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
I doubt it will catch much, actually. What you are seeing is eventually causing the excessive carbon buildup I believe.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 02-07-2014, 01:41 PM
Smalls1000's Avatar
What do you mean?
Sent from my XT1030 using BimmerApp mobile app
Old 02-07-2014, 01:44 PM
thekurgan's Avatar
Bad Lieutenant
What do you mean?
The entire thread is interesting, but I don't see this being helpful.
http://www.bimmerfest.com/forums/sho...9&postcount=43
Ilse
Bruna
BMWCCA #453648
Old 02-07-2014, 05:00 PM
All the way to the intake valves....
Old 02-07-2014, 06:02 PM
blue boy's Avatar
blue boy blue boy is offline
Mein Auto: 2011 328ix
in my opinion every high compression engine should have a factory intake runner port set up for periodic intake and valve cleaning ,, ie every 15k or so.
surely goodness and mercy will follow us all the days of our lives
2011 328IX
Ford 150
Gen 3 Prius
Goldwing Trike
Mustang with mods
Old 02-07-2014, 06:36 PM
Then you would have to admit it is a problem!
Who is going to do that?
