The X5 SAV Forum
Old 02-09-2014, 02:04 PM
roadster8er roadster8er is offline
Mein Auto: 328 325 x5
2003 3.0 head gasket repair
Howdy folks My wife's 2003 x5 has been loosing oolant. Now visual milky water on oil cap. I was wondering if this is a common problem. I assume its a head gasket and not a cracked head. Any advice would be appreciated. Do I replace head bolts? use studs? Are there good better best gaskets?
Old 02-09-2014, 02:33 PM
chatcher chatcher is offline
bmw addict
Mein Auto: e46 m3
The chocolate milk on the oil cap can be from excess condensation inside the motor possibly from a plugged up oil separator. This is not ness a sign of a blown head gasket. Unless the dipstick looks the same as the oil cap you should look for a coolant leak elsewhere.
current rides:
03 E46 M3
08 E70 4.8i X5
03 E85 2.5 Z4
05 E83 3.0 X5
03 350Z
12 Lincoln Navigator
03 rc51
08 F450 Dually
99 F350 Dually
RUNNING OUT OF GARAGE SPACE!!
Old 02-09-2014, 04:20 PM
Dip stick looks good as does the oil. It would be nice not to need a head gasket. I plan on just keeping an eye on it till the weather warms up.
Old 02-09-2014, 08:46 PM
Scott ZHP's Avatar
Scott ZHP Scott ZHP is offline
We want the Lion!
Mein Auto: 03 ZHP, 01 X5, 73 MGB
+1 on condensation, check your CCV. Coolant loss is often caused by a cracked expansion tank.
JUST...LOOK...UNDER...THE...CAR....for Chrissakes....it`s like checking to see if a dog is male or female....
Originally Posted by smolck View Post
A bimmer with forced induction should have a proper manual gearbox. Anything less is like french kissing your sister.
Old 02-10-2014, 12:23 AM
AJR1982's Avatar
AJR1982 AJR1982 is offline
Mein Auto: 525i 2002 & x5 2002
Are you driving it at least 10 minutes after the needle his the first line on your temp?
My car's a bum!
Old 02-10-2014, 06:59 PM
I would have to say No, she only drives about 10 minutes to get to work. I don't think it has reached operation temp but once or twice a week
Old 02-10-2014, 07:19 PM
AJR1982's Avatar
My wife's X5 was doing the same thing and it was just because the temp wasn't staying high enough. I began warming my wife's car up before she headed to work and "POOF" problem solved.
I would not suspect these two problems to be related. You may have a leak in your coolant system but probably not into your oil. The oil is probably just not reaching temp for long enough. With that said it is hard to tell where your coolant system. If it was dry out I would suggest throwing some flour under your radiator and looking for blue to trace it.
