Unlock DVD Region / Area Code - Bimmerfest - BMW Forums
Old 02-10-2014, 12:16 AM
mckenzin mckenzin is offline
Mein Auto: 2010 X5 3.0D
Hi there,
I have recently purchased a UK imported 2010 X5 (CIC). The front Multimedia DVD Player is set to Area-Code 2 for DVD. Unfortunately here in New Zealand we use Area-Code 4. Can I unlock region coding on the Multimedia DVD Player?
Old 02-11-2014, 12:37 PM
ard ard is online now
Resident Curmudgeon
I suspect you need to get into "coding" to be able to set this. There is a sub forum you should check out.
maybe member blue dragon will chime in....
Nice corner of the world you have there, BTW....
Old 02-11-2014, 06:17 PM
brian5 brian5 is offline
nothing today
Mein Auto: 08 X5 4.8i
ard is probably correct about the coding requirement.
When coding, the CIC module allows you set the AREA_CODE_DVD (the DVD region code) to:
area_code_1
area_code_2
area_code_3
area_code_4
area_code_5
area_code_6
alle_anderen (all others)
Old 02-18-2014, 08:20 PM
mgarciah's Avatar
mgarciah mgarciah is offline
Mein Auto: 320i, X3 and X5
Yes, that the way it works, I got my CIC from Finland with region 2, all my movies are in region 1, just change the AREA_CODE_DVD to 1 and that's it, some forums talks about FA or VO change for this to work, you wont need this unless you want to make it permanent.
if you just change the programming and you have your car recoded at the dealer you will be back to the default region, but you can go and change it again.
Old 12-12-2014, 09:22 AM
SweetBMW SweetBMW is offline
Mein Auto: E60 520d
There are rumours that you can only change the region by coding 5 times, then it will lock to that last region.
dvd unlock
