The X5 SAV Forum
Old 02-11-2014, 05:54 PM
mastercraft1990 mastercraft1990 is offline
Mein Auto: Silverado
new X5
I found a 2006 6 cyl with 105K on it. 1 owner, purchased and maintained same dealer, good carfax. Wife wants a BMW, is it safe if it was maintained 13,500.00
Old 02-11-2014, 06:11 PM
DirtyDan's Avatar
DirtyDan DirtyDan is offline
Mein Auto: 2003 X5 3.0i
Wow sounds like a good deal if it has had all the maintenance. Just know it may need all the basic care that goes on with an X5.
Items I have done since I bought my 2003 3.0i 4 years ago with 89k, now has 142k. I paid $14,400.
Alternator
Battery
Transmission drain and filter
Front right half shaft with CV boot
CCV system (pcv valve)
DISA idle control
Plugs
Lower ball jonts
Control arm bushings
Tie rods
Old 02-11-2014, 06:28 PM
lahermano lahermano is offline
Mein Auto: x5
Alternator
Battery
DISA idle control
Plugs
Lower ball jonts
Tie rods
Did u say u got the "Transmission drain and filter" job ?
what did it cost you and is this a dealer job ? or u got it done with Indy ?
Old 02-11-2014, 06:45 PM
DirtyDan's Avatar
Yes at about 110k drained the transmission and filled myself. This just did a partial fluid change. Then my neighbor has his own business out of his house and he dropped the pan and changed the filter. I think I spent $100 bucks total. Filter with gasket and used Valvoline Maxlife DEX/MERC. The shift selector linkage gasket is leaking slowly and will need a transmission shop to fix the $5 part but will have to do the fluid change over again. I have just watched to make sure its not leaking bad.
