Old 02-12-2014, 01:43 PM
kuchdut kuchdut is offline
Mein Auto: 335i xDrive
Tires and wheels, oh my
I've found some reading on these topics, but nothing that solidly nailed my questions. So, I figured I'd put them out here...
I have a 2013 335 xdrive coupe with (what I believe are) the stock Contis, 225/45/R17. I have in my garage the Conti DWS that came off my WRX (probably should have done straight snow tires vs all-seasons in the non-summer months, but decided not to)
The DWS are 235/45/ZR17's. I BELIEVE that I should be able to swap them, even tho the tire will be a little larger (since 45% of 225 is going to be smaller than 45% of 235).
But I wanted to ask if anyone has done this in the past with any success? I can't imagine there being any rubbing, my tires are no where near my wheel wells...
My second question is regarding wheels...I was considering getting some new wheels, but if I do, I'd prefer to get 18's, vs the 17's that are on there. Is that a transition (from 17's to 18's) that you can just make? Or is there more to it than that?
Thanks for any help
Old 02-12-2014, 01:52 PM
Momukhamo Momukhamo is offline
Send a message via AIM to Momukhamo
Mein Auto: 335i xdrive
HMM you can always just get bigger rims from 17-18 ive seen people do it from 17-20 lol just make sure you have the same rolling diameter if you go staggered or just get a square set of 18's
i bought 19's no tires yet tho hehe..
Old 02-12-2014, 01:54 PM
oh and i think not unless you get something like 18x10 or 18x9.5 especially in the front then u might start rubbing.
Old 02-12-2014, 05:56 PM
Thanks for the info on getting bigger wheels. I have some add'l homework to do, but I think I'll officially start shopping for a summer set.
Those 19's look sharp...Post some pics when you get them loaded up.
Old 02-12-2014, 06:00 PM
ModBargains IV's Avatar
ModBargains IV ModBargains IV is offline
Mein Auto: e92, e82, e46, e39
Thanks for any help
Going up to a 235/45/17 means you are only adding 5mm per side, so I think you'll be fine.
As far as 17'' vs 18'' wheel setups, you'll find that there are a lot more options 18'' available for a BMW 335i because of the brake clearance. Even some 18'', because of the barrel design, won't fit over the factory 335i brakes.
If you have any further questions, feel free to shoot me a PM or email me at frank@modbargains.com
Frank Kim | Frank@Modbargains.com | (714) 582-3330 ext 8003
Hours: Monday - Friday 8:00AM-6:00PM, Saturday 8:00AM-5:00PM (PST)
| Our Blog
Old 02-17-2014, 09:41 AM
Thanks Frank...I'll probably hit you up at some point. I'm going to be looking for 18's in gun metal or black. I've been doing a little looking and it seems the ones I find don't fit the 335 xdrive coupe...
I dig these (I believe that's a 6-series)
Old 02-17-2014, 10:58 AM
Zooks527's Avatar
Zooks527 Zooks527 is online now
Winding up the M235xi
Past the rubbing issue, you'll close down your speedometer error with that set. The new diameter will lower your speedometer reading by about 1.4% at all speeds.
Old 02-17-2014, 12:03 PM
wilt wilt is offline
Mein Auto: 2011 328i
Tire Rack doesn't seem to raise any issues of fitment of 235/45R17 Continental DW on 2013 335i coupe. Diameter increase seems to be 0.3"
As for speedometer accuracy, larger tire merely decreases the 4mph optimism found in stock form!
But as you live in snowy Colorado, do you really want to increase to 235/45 rather than 225/45?!
Old 02-17-2014, 12:14 PM
the more I've been thinking about it, I think what I may end up doing is buying a set of 18" wheels and putting some proper summer tires on them, and then selling the 2 sets of Continental A/S tires I have an grab some true snow tires and keep those on my stock 17" wheels.
...speaking of which, I was a little surprised to figure out (4 months later) that I have 17's on here (335 xDrive, M-Sport)...I thought for some reason there were 18's on the M-Sport, but it must have been ANOTHER option. My buddy has an 07-08 335i Coupe that came w/ 18's. Never-the-less, I just need to decide which wheels I'm going to get for my Summer kicks.
Old 02-17-2014, 06:25 PM
Zooks527's Avatar
That's a smart move.
The xDrive sport options go with 17" unless you upgrade to the optional 18" staggered tires. RWD goes with 18" from the get-go on the sport package. Odds on you don't have the oil cooler, as it sounds like the car was delivered with the base 17" A/S RFT tires, which don't include the "increased speed limiter" package that adds the 18" stagger and the oil cooler.
No problem stepping up to the 18s, it's mount and roll with the right size selection. (225/40-18 front, 255/35-18 rear).
Old 02-17-2014, 07:00 PM
Beautiful...thanks for the info Zooks! I always wonder how folks come up with all this info. It's so helpful...I presume it's a greater capacity for retention that benefits most
One other thing (ok, more like 3 things):
Should I be looking at 8.5 front & 9.5 rear? Is staggering f/r preferred over 4x 8.5?
Off-set always going to be 35mm?
I'm trying to narrow down my selections and want to make sure I don't end up with something I can't use. I've never bought after-market wheels for ANY car I've owned (Surprising, I know) and I've not put that much thought into bolt patterns, off-sets, etc...my head is starting to hurt
Thanks for all the info
Old 02-18-2014, 03:54 AM
Zooks527's Avatar
Well, much of that is info I can't give, as I run 17" tires year round, although I do have a dedicated winter set of Blizzaks.
I do know that you can go square or use the staggered 18" sizes above (which are what come with the stagger package on the xDrive models from BMW). I can say I've never quite seen the point of a staggered set on an AWD past appearance, so IMO stagger vs. square is whatever gives you the look you prefer.
EDIT: Here's a new thread you may want to look at: http://www.bimmerfest.com/forums/sho...d.php?t=753526
Money quote from post #3 in that thread: "Btw with a stock xi suspension, you increase understeer with a staggered setup. "
Old 02-18-2014, 02:32 PM
Thanks again for the info Zooks. I believe I'll be looking at using all the same size wheels...Just be easier for my tiny brain to comprehend...And it seems like it would have some impact on tire longevity as it relates to rotations (?...maybe not)
