Old 02-12-2014, 04:08 PM
mikesevel's Avatar
mikesevel mikesevel is offline
Mein Auto: 328i convertible '08
S.I.B. auto trans, mechatronic sleeve repair
Taking my '08 328i E93 to an Indy tomorrow for an oil change and inspection as my CPO warranty expires in April. I have been reading about the leaking mechatronic sleeves in the auto transmissions. Repair instruction RA2434020 refers to ZF transmissions 6HP26 and 6HP19.
Without a lift available at home, how do I know what transmission I have?
Mikey
Old 02-12-2014, 04:13 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Mikey
I believe the 328 series uses the GM sourced unit, not any of the ZF units.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 02-12-2014, 05:20 PM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
Yes GM but you are worried about an outliar event.
Have your indy check for oil filter housing gasket leak / valve cover gasket leak / any other oil leaking viewed from underneath the car on a lift.
Have them check the serpentine belt ... is it riding off the tensioner pulley (even 1/4 inch).
Are you covered for battery? If its original its on its last legs.
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
(Hey Jim... am I diversified?)
Old 02-12-2014, 07:57 PM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
+1 you have neither and are not affected.
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
