Old 02-13-2014, 11:34 AM
calvinbmw calvinbmw is offline
Mein Auto: 335
Buying new tires, do I need new value stems and TPMS rebuild kit?
I am buying new tires online, there are 2 recommended optional items:
TPMS Rebuild Kit
Valve Stems
Do I need any of those? I found some info online that the TPMS Rebuild Kit include valve stems already? So do I need to order either of those or both?
Old 02-14-2014, 10:11 AM
S3RI35 S3RI35 is offline
Mein Auto: 09 335i
you need both. If you don't order them online, ur installation shop has them. They're usually around $7-10 each.
2009 E90 335i | CA | Sport | Space Gray
2008 A4 Quattro | S-Line | Sport | Ibis White - Dealership Totaled
2006 Impreza Outback Sport | Silver/Grey Metallic - Retired
Old 02-14-2014, 11:43 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
IIRC, the TPMS kits include the valve stems.
In my case, I decided to have the shop supply them (they usually have all the parts in hand). Adding the TPMS rebuild kit to my last tire order added an extra $10 to the shipping charge, which seems rather high for an envelope with 1/2 ounce of parts in it.
Old 02-14-2014, 04:43 PM
Princeton Princeton is offline
Princeton
Mein Auto: 2008 335cxi
I am on my third set of tires. I did not use new valve stems or get the TPMS rebuilt or replaced. In fact, my indy shop recommended against it. YMMV
2008 335cxi:GRAPHITE METALLIC:JADE GRAY:GRAY POPLAR:PREMIUM:SPORT:HEATED SEATS:NAV:IPOD/USB
