Old 02-14-2014, 01:56 PM
rideme2's Avatar
rideme2 rideme2 is offline
rideme2
Mein Auto: 2006li bmw
Rear comfort seat not working?!?!?
What's up guys?!? It's been some time:-)) it's a good thing cause the car been good till now:-(((( so I couldn't find anything on this??? Ok my right side rear seat stopped working. The fan and heat also??? The seat doesn't move at all? But that same switch works for the front seat still?? So I don't think it's the switch?? For the guys with rear comfort seats, there a button on the armrest that you hit to control the front right seat so that the rear passager can move the front seat to there likely. Any idea???
2006 750li K&N Filters Giovanna Kilis on 265/30/22 305/25/22 HID fogs 6000k Mtec angel eyes all lights 6000k ACS front lip,ACS rear wing,ACS rear window wing.dual exhaust working qual tips, rear camera, upgrade DVD to front watch jl13.5t sub with jl500/1v2 amp power cap.PassPort 9500ci,CrossDrilled&Slotted Rotors with EBC Brake Pads.Rear comfort seats, Fully loaded from dealer. Next mod iPhone hookup, .
Old 02-14-2014, 05:06 PM
TechFreak TechFreak is offline
Mein Auto: AC Schnitzer 745i Sport
On driver's door there's a button that locks out the rear windows in the back. It also locks out ALL electrics in the rear including the seats. It's to stop kids messing about with them.
Make sure the the little green light isn't 'on' on drivers door and try your seats again. ;-)
Sent from my GT-I9100P using BimmerApp mobile app
My BMW ACS7
Old 02-14-2014, 05:09 PM
rideme2's Avatar
rideme2
Yea I know about that. But only one seat is not working.
Old 02-14-2014, 05:17 PM
Ok. Sounds like it could be a faulty 'seat module'.
It's just a direct replacement and no coding needed.
My BMW ACS7
Old 02-14-2014, 05:20 PM
rideme2's Avatar
rideme2
Ok do you know where it's located? I didn't see anything under the seat? But the pumps?
Old 02-14-2014, 05:22 PM
To test it you could swap the rear left and right seat modules over to see if the fault transfers over too.
My BMW ACS7
Old 02-14-2014, 05:23 PM
rideme2's Avatar
rideme2
Ok but where are the modules?
Old 02-14-2014, 06:12 PM
rideme2's Avatar
rideme2
I think it's in the trunk of the car?? I found one on EBAY, just to see what it looks like. And it's too big to fit under the seats.. I'll open up the panels in my trunk to see if I can find them???
Old 02-14-2014, 08:36 PM
dvanlare dvanlare is offline
Mein Auto: '95 E31, '05 E66, '15 F02
Yes, trunk -- left side behind wheel arch trim.
Old 02-14-2014, 11:45 PM
vichugo vichugo is offline
Mein Auto: 2002 745i
Look at the sticky "Found an interesting E65 Tech Doc". The location of all the modules is given on page 35-37 of the pdf document in post #1.
There are so many modules...
2002 745i toledo blue, shades, comfort seats, winter package, MTECv2 halos.
Old 02-15-2014, 01:00 AM
inspi inspi is offline
Mein Auto: 03 BMW 745i, 06 BMW 750Li
Check the fuse also
INSPI
Old 02-15-2014, 05:25 AM
rideme2's Avatar
rideme2
Originally Posted by inspi View Post
Attachment 422792
Check the fuse also
All fuses are good. I checked the one in trunk and glove box. So there one module on each side?
Old 02-15-2014, 08:14 AM
rideme2's Avatar
rideme2
Ok just check the seats modules, I swapped them and the problem didn't followed... the same one seat not working? now I want to removed the switch from the armrest. is hard to remove?
Old 02-15-2014, 10:35 AM
INSPI
Old 02-15-2014, 01:30 PM
rideme2's Avatar
rideme2
thx for the pictures helped a lot. but the seat switches can't be swaped!!!!! different pin out. there's another module in the armrest that all of the switches goes into in the rear. I'm thinking that module is bad cause what are the chances of two switches goes bad in the same side. the left seat control and the air switch and heater switch are not working at all on the left.
Old 02-15-2014, 02:28 PM
Do diagnostic, check for codes, read status...
INSPI
