Cylinder True Running Value - Bimmerfest - BMW Forums
Old 02-15-2014, 12:55 PM
wjjklj's Avatar
wjjklj wjjklj is offline
Mein Auto: 2013 BMW M5
Hello friends, I used to hang out here more often when I had my E65. I bought a 2009 F01 last year with 16k miles on it and now have 23k miles on it. So now I am more often on that forum. Definitely more people on this forum that work on their own cars....that being said, I need your help.
My car started running rough at idle and felt like it was going to die at red lights. I scanned the car and it said misfire cylinder 8. I ran some Techron fuel injector cleaner through it and the idle smoothed out dramatically. When I look at each cylinder true running value, all are close to zero except cylinder 8 which is -6.00 and higher. Any idea what this means? Bad injector? Thanks in advance.
Old 02-15-2014, 12:56 PM
wjjklj's Avatar
ID:	422927Click image for larger version
Old 02-15-2014, 01:11 PM
dvanlare dvanlare is offline
Mein Auto: '95 E31, '05 E66, '15 F02
It's a different car (e39) but here they talk about a bad spark plug causing it and there is also mention of the coils.
https://www.bimmerfest.com/forums/sh...d.php?t=446046
Old 02-15-2014, 02:55 PM
wjjklj's Avatar
Thanks for the link. I am curious what the number means. Does positive mean the fuel is too rich and negative mean running too lean?
Old 02-15-2014, 06:27 PM
DMAX745i's Avatar
DMAX745i DMAX745i is offline
Mein Auto: 2013 750xi & 2002 745i
Hope its not a bad injector. Last guy blew motor, bent crank rod and damaged piston. Seems 09-10 few peeps had bad Injector problems. There is a thread just posted recently. Hope its not the samr type of problem.
DMAX745i
Old 02-15-2014, 06:32 PM
DMAX745i's Avatar
Oops, lol. Thought I was in F01 forum. Seems n63 motors have bad injectors and really mesd up things.
DMAX745i
Old 02-15-2014, 06:39 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
F01/02 have had multiple inejctor redesigns over the last few years. Get yourself some new ones and try it out. Also I suggest buying a new coil pack that you can use in the future for troubleshooting.
2013 TL Advance 3.5L
2006 BMW 760Li - Alpine White/Ebony-Ivory Two Tone
2010 Honda Accord EX - Basque Red/Ivory
lOE Fog Lightsl
2007 MDX Sport/Ent.- NGM/Taupe
lRB Slotted RotorslRoof RailslFront & Rear GarnishlAuto Mirrorl
2004 TL NAVI Auto - SSM/Quartz
lComptech SwaybarlHacked NavlTVNAV2GolUSA-SPEClDVD PlayerlSwitchblade KeylRB Slotted RotorslA-Spec Brakesl
Old 02-15-2014, 11:55 PM
inspi inspi is offline
Mein Auto: 03 BMW 745i, 06 BMW 750Li
It's leaking injector, must be change
INSPI
Old 02-16-2014, 10:09 AM
wjjklj's Avatar
Thanks for the replies guys...guess I'm going to replace all injectors, coils, and plugs. Can't believe I have to do this on a car with 23k miles. Any idea what the numbers mean either positive or negative? Lean or rich?
Old 02-16-2014, 10:10 AM
wjjklj's Avatar
Also, know any software that can code an injector on a F series?
