Old 02-16-2014, 08:54 AM
le0.br4zuc4 le0.br4zuc4 is offline
Mein Auto: 2007 335i
2007 BMW E90 335i OIL LEAK - NEED HELP!!!
This car has 78k miles on it, I am the second owner and I have it for about 6 months now. For the past month I noticed a oil leak, noticed when driving and I stop the car I smell a strong burning oil smell and now there is a smoke coming from the bottom of the engine everytime the engine gets warm.
I took a look at the bottom of the engine, noticed the oil is leaking from somewhere onto the exhaust pipe (probably what's causing the smoke and smell). I can't see where the oil is coming from.
I took 2 pictures of the 2 places I noticed oil when I look from underneath the car, there is absolutely no oil leak marks when you look from the top of the engine.
If anyone has any idea where the oil leak could be coming from or is able to provide any help I would really appreciate it.
I don't know what this is, it isn't close to the exhaust on the picture below. It is more towards to the front of the car, closer to the front bumper.
This is the exhaust, hard to see but the oil is dripping on here.
ID:	423085   Click image for larger version
Old 02-16-2014, 09:40 AM
mvvette97 mvvette97 is offline
Mein Auto: 08 328i
it's the valve cover gasket. seems to be a common problem. I am learning this as well being new to bmw. I just fixed the oil filter adapter gasket on mine cuz they are a problems area also. Haven't had to do the valve cover gasket on mine yet but honestly I don't think it will be very hard to change.
Old 02-16-2014, 11:12 AM
Thank you very much for your help. I went ahead and removed the engine top to see if I could see any signs of oil anywhere, I found a metal plate to the side of the engine with oil in it. the metal plate is directly above the exhaust (pictures posted in first post) so I think you were 100% right on the problem.
this is the metal plate I was talking about.
I am ordering the part now, should have it in a couple of days then I will try to change it my self.
thanks a lot.
Old 02-16-2014, 11:57 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
thanks a lot.
AHEM
Harumph!
Old 02-16-2014, 01:09 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
Valve cover leaks is very common
leaks on mine at 30,000km
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 02-16-2014, 01:19 PM
Miller335 Miller335 is offline
Mein Auto: 2007 E92
This isn't directed at OP but ya know, been on these boards for a little bit of time now and while these cars do have some things that fail sooner than other manufactures it's very predictable at this point and so far I've found that working on my BMW isn't that much harder than other manufactures I've worked on.
GL OP, you're in good hands.
Old 02-16-2014, 03:09 PM
I'm glad to see that. I hope I find it easy too, I come from Audi and didn't have much issues working on that.
Old 02-17-2014, 08:23 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Only thing about these cars I am seeing (but haven't needed yet) is when something needs to be reprogrammed. Otherwise, it's a car with parts in very tight spaces.
