Old 02-16-2014, 02:03 PM
davey546 davey546 is offline
Mein Auto: bmw 330i 2006
No air coming out of vents.
Hello,
My bmw 2006 330i e90. 2 weeks ago my car stop blowing air out of the vents. Like I turn it on at max speed/low speed on ac or heater and no air comes out of any vents. I can hear the air compressor turning on like it use to. But no air. I checked the fuses in the glove compartment all good fuses. I checked the fan and its turning. I noticed a pipe close to the compressor gets ice cold and turns white. I don't know if thats normal? I don't know what it is. anyone know what it might be? Thank you
Old 02-16-2014, 02:08 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
ddi you turn air cond on ?
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 02-16-2014, 02:10 PM
Also I forgot to mention. That the button that says "rest' for heater wont work like it wont light up. But the button for "max" for cold air works and lights up.
Yes I did
Old 02-16-2014, 05:09 PM
Mein Auto: '06 AW 330xi
Most likely a bad blower motor. Check the windshield cowl cover. It should be flush with the glass.
If its not, fix that. Then replace the blower motor.
Otherwise, you will have the same issue again.
Another indication the cowl cover caused this, is a wet passenger floor.
Old 02-16-2014, 05:46 PM
I checked it wasn't that.
Old 02-16-2014, 09:07 PM
Tom K.'s Avatar
Tom K. Tom K. is offline
A bad final stage resistor may also be the cause.
Tom
Old 02-16-2014, 09:26 PM
ArturoE39IT ArturoE39IT is offline
Mein Auto: 99 528IT
i have the same issues on my 528it. i am going to try this. thanks for the tip!
