E34 (1989 - 1995)
Old 02-17-2014, 05:03 PM
texanfez texanfez is offline
Mein Auto: 1995 bmw 525i
Should i be worried
When I start my 525i up says "coolant"thats it. But when I drive off within 10 seconds it goes off.Should I be worried?
Old 02-17-2014, 05:14 PM
imae34driver imae34driver is offline
Resident e34 Racer
Mein Auto: 1995 540i SPORT /6 spd
Check and Add coolant.. LOL
Make sure none is in the oil.
Bone stock 95' 540i/6 Blk/blk w/ ram style C.A.I / JBR LWFW/ DUDMD tune/ straight pipe /545 SSK /3.15 LSD / Rev-shift motor mounts/stage 4, 6 puck clutch/ K Sport coil overs/Eibach sway bars/ VAC under drive pulleys/weight reduction /sparco 368, Recaro seats, sparco harnesses, NX wet kit, M/T E/T streets.
"Skill can only get you so far, then comes money!"
R . I . P Paul Walker - 1973 - 2013
Old 02-17-2014, 05:19 PM
Coolant is fine. I checked that first thing.
Old 02-17-2014, 05:22 PM
Resident e34 Racer
Can just the sensor.. Check the wires, there known for being fragile..
Old 02-17-2014, 05:59 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
^+1
Here is a pic of the frayed wires that can cause the message:
This connector is located at the bottom of the radiator on the driver's side.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 02-17-2014, 06:34 PM
mda185 mda185 is offline
Mein Auto: 95 525iT w/S52, 03 530i
Agree with above posts. Both wires and sensor itself can fail after 15+ years. I had to replace sensors in my 95 E34 and 97 E36. It is easy repair if done when you are changing coolant. You should change the coolant at least every couple years. I do mine every 12 months.
Old 02-20-2014, 03:58 PM
Mr-Dee Mr-Dee is offline
Mein Auto: BMW E39 525i Sport
I have a quick question on coolant level . . .
Hi, I have a manual e34 520i M50 and have recently been doing many checks on the cooling system after an 'episode' of sudden coolant loss, I think I have found the cause now, when the engine is running I have noticed that the water pump pulley seems to move in and out slightly :-/ but while checking other things I thought . . . hmm how come I got no indication of 'Low Coolant Level' ! ? and I am wondering if its only the automatic models that have the level sensor in the radiator reservoir ? have looked in my Owners Manual and I cannot seem to find a warning light/indication for low coolant level. so do I have an aftermarket radiator ? or do some models (maybe manual versions) not have the Low Coolant Level warning ?
Any advice would be appreciated as I cannot seem to find an answer to this anywhere
Old 02-20-2014, 07:51 PM
E34ZombieHunter's Avatar
E34ZombieHunter E34ZombieHunter is offline
Nothin like an E34
Mein Auto: 95 540i B/B
If you had a low level it would say it on the dash
COOLANT LEVEL
is what you would see followed by OWNERS MANUAL
Press the check control button to scroll through any messages.
It is the right button on the dash.
Gotta love an E34!!
If you want to get junkyard parts remember one thing, if it was wrecked you know it was running/driving. You may not know how well, but it was.
READ THE STICKIES AT THE TOP OF THE PAGE!!
STOMP TEST
READ ME IM THE BIBLE
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 02-22-2014, 09:37 AM
I did have low coolant level because there was no water in the radiator reservoir, but I had no warning, I have no 'check control button' Owners Manual shows 2 instrument clusters, mine is the one without the check control display
