Old 02-18-2014, 04:02 PM
eco88 eco88 is offline
Mein Auto: 35d
error codes... Bavarian Technic
Ok, so 2 weeks in, the engine light came on.
I already had ordered bavarian technic cable a while back (in anticipation) and got to use it today.
These are the codes I got (now for some codes it says 'not currently present' yet it still shows them, bit confusing).. there are so many, pretty scary
Any of these need attention asap, or are they ok to live with?
Thanks in advance
Diesel Engine module
4BB2:
Error will not cause a warning light
Error is not currently present
Test conditions have been completed
Short circuit or signal interruption
4D16:
Error will cause a warning light
4C7C:
DDE: Reducing-agent metering valve, activation
Gear lever
Current Fault Codes
A833:
Unlock button jams
Dynamic stability control - 4 wheel
Current Fault Codes
6E82:
Car Access System 3
Current Fault Codes
A128:
DUMMY Z
Junction box - passenger
Current Fault Codes
A6D1:
Auxiliary water pump
Air conditioning control panel
Current Fault Codes
9C69:
Audio system controller
Current Fault Codes
C5A0:
Error is currently present
Old 02-18-2014, 05:38 PM
ingenieur ingenieur is offline
Mein Auto: 328d
Thanks in advance
4BB2:
4D16:
4C7C:
Gear lever
Current Fault Codes
A833:
Unlock button jams
Current Fault Codes
6E82:
Car Access System 3
Current Fault Codes
A128:
DUMMY Z
Current Fault Codes
A6D1:
Current Fault Codes
9C69:
Current Fault Codes
C5A0:
SCR efficiency
4D16:
Perhaps the other SCR fault is related.
4C7C:
If the SCR system does not function as required it could result in a no start countdown.
Is the active tank full - because the passive tank may be frozen.
Country Roads take me home...
Old 02-22-2014, 11:13 PM
ard ard is offline
Resident Curmudgeon
Dont be so freaked...codes happen.
Keep in mind that once a code is set it stays in memory- could stay for 2,3 years and 40k miles...then when you get some othjer fault you read codes and they all show up. (This is what the 'not present' means- so it isnt currently an 'active' fault.)
Reset the cdes. Read them. confirm the 'paper is clean'
...now drive it and see what comes back.
GL
report back
Old 03-04-2014, 10:43 AM
Mein Auto: 35d
thanks for the replies
I got the adblue today, will top it up... otherwise everything seems to work fine...
