E34 (1989 - 1995)
Old 02-18-2014, 06:02 PM
Larrick Larrick is offline
Mein Auto: 1994 525it
Are BrakeBest Select Ceramic Pads from O"Reilly Auto OK?
What pads are recommended for 1994 525it?
Old 02-18-2014, 06:48 PM
imae34driver imae34driver is offline
Resident e34 Racer
Mein Auto: 1995 540i SPORT /6 spd
They should be fine, may sqeek when cold.. Get the best you can afford
I use ceramics for less brake dust mainly.
Bone stock 95' 540i/6 Blk/blk w/ ram style C.A.I / JBR LWFW/ DUDMD tune/ straight pipe /545 SSK /3.15 LSD / Rev-shift motor mounts/stage 4, 6 puck clutch/ K Sport coil overs/Eibach sway bars/ VAC under drive pulleys/weight reduction /sparco 368, Recaro seats, sparco harnesses, NX wet kit, M/T E/T streets.
"Skill can only get you so far, then comes money!"
R . I . P Paul Walker - 1973 - 2013
Old 02-19-2014, 07:40 AM
The BrakeBest Select seem to get good reviews on other forums
when I Google the subject.
They are supposedly manufactured by Bosch.
I say supposedly because I have seen it mentioned several times
but can not find an actual confirmation.
Perhaps O'Reilly Auto can tell me.
I am using ceramics.
Old 02-19-2014, 09:41 AM
Doktor Bert's Avatar
Doktor Bert Doktor Bert is offline
Der Sturm Uberdoktor
Mein Auto: BMW 525i
I use only PBR Organics on a street car. Australian made and available online or at NAPA...
"Herr Doktor will see you now..."
Old 02-20-2014, 06:35 PM
I decided to go with the BrakeBest this time as I did not want to wait.
When we looked at the rear brakes, they looked like they had some good
miles left on them but would need changing soon enough so we did the rears.
The brake sensor light had come on because the wire had been rubbing against the
tire and had finally worn through.
The front brakes were fine.
Interestingly the rear brakes come with a new sensor installed but
the fronts do not.
Old 02-20-2014, 08:07 PM
CitizenOfDreams CitizenOfDreams is offline
Mein Auto: 1998 BMW 740i
I'm using BrakeBest pads on my E38, haven't noticed any problems. No noise, no dust, adequate braking power.
