E34 (1989 - 1995)
Old 02-19-2014, 01:53 PM
espektor espektor is offline
Mein Auto: 1993 e34
Thumbs down 1993 e34 no crank no start
I have an issue with 1993 525i sedan, 25k 6cyl, 2.5
I jumped it once and batt was dead, hade some smoke come up from under the bottom of the car, under the hood on the driver side. Started after charging the battery, but not right away, a few cranks. Took it out a few time with no problems. Now will not start.
Tried to jump with 2 different good batteries, just a click, seams behind the driver seat, in the back but no turn of any kind, dashboard lights up as usually, locks work, lights work.
where should I go from here, I am a newby mechanic, but do have common sense, please help.
ES
Old 02-19-2014, 02:15 PM
E34ZombieHunter's Avatar
E34ZombieHunter E34ZombieHunter is offline
Nothin like an E34
Mein Auto: 95 540i B/B
Sounds like the starter went.
Would also check the wiring to it.
Gotta love an E34!!
If you want to get junkyard parts remember one thing, if it was wrecked you know it was running/driving. You may not know how well, but it was.
READ THE STICKIES AT THE TOP OF THE PAGE!!
STOMP TEST
READ ME IM THE BIBLE
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 02-19-2014, 03:52 PM
Doktor Bert's Avatar
Doktor Bert Doktor Bert is offline
Der Sturm Uberdoktor
Mein Auto: BMW 525i
With a test light, check that the solenoid wire on the starter is getting 12VDC when the key is turned to start. If you do not have a start signal, remove the back seat and pull the GM (General Module.) They will crank and start without the GM...
"Herr Doktor will see you now..."
525i, e34, e34 1993, starter e34, starting e34
