Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series
3 Series / 4 Series
The 3 Series / 4 Series Forum. If you would like to see all new posts in all the forums, click here.
Old 10-16-2004, 01:24 PM
Rmart's Avatar
Rmart Rmart is offline
Mein Auto: 08 Jetta
Brake Job Cost?
What does a front and rear brake job cost at an independent BMW shop or at a dealership? I believe I need new rotors in front and pads all around.
Thanks...
Old 10-16-2004, 05:02 PM
norihaga's Avatar
norihaga norihaga is offline
Achtun*, Spitfire!
Mein Auto: '93 E30 318is Touring
At least a grand at a dealer is what I hear - less at an independent. Or do it yourself for about $300 in parts (all pads + rotors).
Old 10-16-2004, 07:31 PM
Arthur's Avatar
Arthur Arthur is offline
04 IR/NB ZHP
Mein Auto: 04 Imola Zhp
all brake jobs will include pads and rotors. bmw uses soft rotors that are worn down so far that not replacing them at the time the pads are replaced means another trip to replace them shortly. my independent shop charges 275 a set. just under 600 for all 4;
Old 10-16-2004, 07:35 PM
F1Crazy's Avatar
F1Crazy F1Crazy is offline
racer wannabe
Mein Auto: '12 X5,'08 535i, '03 325i
It's not true that BMW rotors are softer than other makes, they are simply thinner. Look for posts from DZeckhausen, he explained it at least few times.
Old 10-16-2004, 08:41 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
If you have reasonably good mechanical skills (or have a friend who does), you can save a *ton* of money by DIYing the job.... I`ve never bought any exotic brake components for any of my BMWs. just OEM-type stuff. IMHO, rotors from ATE don`t last as long as some others....BALO (if you can find them) makes a very high-quality rotor (they have their own foundry and actually make the raw steel for their rotors). When my ZHP needs brakes, I might try a set of cryogenically-treated rotors from:
http://www.frozenrotors.com/frozenrotors.shtml
If you stick to OEM parts, you can DIY the job for about $300 for all 4 wheels.
Regards,
Bob
Similar Threads
Brake Service Cost on X5 3.0i mkh X5 E53 (1999 - 2006) 14 04-26-2006 05:25 PM
Brake job bmwowner Do-It-Yourself H.Q. 25 06-24-2005 06:53 AM
How efficient is the E-brake? yamato 3 Series / 4 Series 27 05-28-2004 10:51 PM
Cost of Coolant and Brake Flush? Zappo M Series 3 10-20-2003 10:49 AM
No more brake dust (using e36 brake pads) K1 3 Series / 4 Series 4 08-01-2002 12:07 AM
