Old 02-20-2014, 08:44 PM
PebblePlace PebblePlace is offline
Mein Auto: 2013 750i
'13 750i High Pitched Sound at 1200 RPMs
We were on way home tonight and I noticed a high pitched sound. My wife and I were talking, so I turned off the stereo and it seemed to go away. Then it came back. Loudest at 1200 RPMs. Above 1200 RPM it seems to fade away, or other noise is drowning it out.
When the car comes to a stop, it goes away after a second or two. Tried turning vents on / off - that made no difference. The whine is not linear with the RPMs, though it does get loudest at 1200 RPMs. It's not like a ground hum from the audio system. It definitely seems mechanical. The Mrs. heard the noise as well.
I did some searches and didn't find any exact matches, but I did find a video with the exact same sound -
The high pitched noise cuts in and out during video. It's not a constant (that would be too easy). None of threads I found pinpointed an exact cause. The all had the same theme though, "dealer heard the sound, but didn't know what it was..."
This noise happened several weeks ago and I was hoping it was a one-time thing or maybe I was imagining things. Has anybody else had a similar problem? Hoping to point the dealer in the correct direction.
2013 750i | Executive Package | M Sport | LED Lighting | 20"
Old 02-20-2014, 08:52 PM
Popoemt's Avatar
Popoemt Popoemt is offline
Mein Auto: 2015 750i
I have the same sound, it almost sounds like it's an issue with a speaker to me (both my wife and I have commented on it in the past and it sounded like it was coming from the front right speaker)?
2015 750i
2013 740 Li (Lease End)
2007 G35 (trade-in)
2003 Z06 (Black, 50th Anniversary)
2001 Z06 (Torch Red)
Old 02-20-2014, 10:15 PM
JacksonY JacksonY is offline
Mein Auto: 2014 BMW 740Li
Rather than simply shutting your vents... have you tried completely turn off the air conditioning and fans...
I have had a similar issue on my E65... it doesnt happen everyday so I am not if it is the same... but it seems to be either something loose within the a/c system and its either vibrating or a/c blowing on a loose piece or a combination of both... I never figured out what it was... I solved the problem by buying a new F02... LOL
But... if you think about it... vibration does make sense... as it is only audible at certain RPM... so whatever is loose on your car probably only resonates at around 1200rpm since the vibration frequency is different at different RPMs and loads...
Old 02-21-2014, 01:10 AM
ChrisF01's Avatar
ChrisF01 ChrisF01 is offline
Gib mir Feurschutz!
Mein Auto: 2016 750i xDrive
Weird, haven't had that on either my '12 or '13. Do the ole' try another dealer and ask for a ride along with a master tech if you get no results.
Best of luck!
Chris
2016 750i xDrive M-Sport (Current)
2015 650i Coupe
2013 750i M-Sport
2012 740Li
Old 02-21-2014, 05:52 AM
Leftlane11 Leftlane11 is offline
Mein Auto: 2012 750Li
I have that exact same high pitched whine in my car on occasion. I have reported it the dealer on my last 2 service visits, and I got the totally predictable "couldn't duplicate" response. I took iPhone video several different times and showed it to them, and they said they have to actually hear it in real time to do anything about it. It's very frustrating - mine seems to happen most often after I've been driving, park somewhere for 20-30 minutes, then start driving again - usually around 1500 RPMs and up to about 40 mph. I've stopped before to try to pop the hood and run around to the front to see if I can pinpoint a location, but it usually goes away after a second when fully stopped.
I have tried all the things above - AC off, vents closed, radio off, etc. - it is definitely coming from under the hood somewhere and piping into the cabin.
Anybody know if this is the oil pump whine I've read about? Ticks me off that I have to waste time trying to chase this down.
I have several videos I can post if you need corroborating evidence.
Old 02-21-2014, 05:59 AM
ImolaMMM's Avatar
ImolaMMM ImolaMMM is offline
Mein Auto: 2013 750 Li
Best of luck!
Chris
+1
I haven't experienced it in my '13 either.
@Jackson, I had a "whistle" in my E66 that ceased once I turned the A/C off. It was very sporadic & annoying. Like you, I corrected it with an F02.
2013 750 Li Alpine White/Black|M-Sport Pkg|LED Lighting Pkg|Exec Pkg|Drivers Assist Pkg|760 Exhaust Tips|Painted Calipers|CQuartz Finest
2008 Toyota Sequoia Platinum--Arctic Frost Pearl/Red Rock
2006 750 Li-Retired
2006 330i-Retired
2002 M3-Retired
2000 323Ci-Retired
1991 M3-Retired
Old 02-21-2014, 06:03 AM
FalconFlyer FalconFlyer is offline
Mein Auto: Tampa
I have not had the issue either, I have 6k miles on 7, how about you guys and when did it start?
2015 BMW M6 Grand Coupe
2016 BMW 750i M Sport
2015 BMW M4 Convertible
2015 BMW X5M
2015 BMW 750Li M Sport (Sold)
2014 BMW X6 3.5 M Sport (Sold)
2014 Viper GTS (Sold)
2015 Jaguar F Type R (Sold)
2015 Ranger Rover Evoque Dynamic (Sold)
2015 BMW X5 5.0 M Sport (Sold)
2014 BMW M6 (Sold)
2013 BMW 750Li M Sport (Sold)
2013 BMW M5 (Sold)
2013 BMW Z4 35is
Old 02-21-2014, 06:38 AM
beamlord's Avatar
beamlord beamlord is offline
Wardaddy in retirement
Mein Auto: g11
Have it as well.
It's not the oil pump (was replaced), it's not specific to the n63 engine (still have it with n63TU), it's not the AC/ventilation/heater (still there with all of that shut down), it's not the speakers (there with music off).
It's mildly annoying but you kinda get used to it I guess. Like the popping/clicking sound from the steering column...
Flagship quality FTW !
2016 G11 M-Sport Torque Monster, singapore grey, shadowline, ivory white / black, black alcantara.
Old 02-21-2014, 06:39 AM
kimg9582's Avatar
kimg9582 kimg9582 is offline
Mein Auto: 2011 740i
I have not noticed this in my 740. It sure sounds annoying though.
2011 740i
Old 02-21-2014, 06:57 AM
Mine is a 2012 750Li - I started noticing it around 15k miles or so.
Old 02-21-2014, 08:28 AM
Popoemt's Avatar
Hmmmm... Now we have a mystery, mine started around 18k, and it's annoying when it happens. I first thought it was tinnitus and when my wife heard it I knew it wasn't just me
It is annoying, although I find by the time I'm recognizing it, it goes away a few seconds later?
That video posted is an EXACT replication of the noise though... My car does sound like it's coming from the front right (which is why I thought it was a speaker issue).
I'd be curious if all of us have the same options (740li sport, B&O, executive package, LED), and could find a reason behind it?
2015 750i
2007 G35 (trade-in)
Old 02-21-2014, 11:54 AM
kimg9582's Avatar
Could the noise be coming from the turbo spooling?
2011 740i
Old 02-21-2014, 01:25 PM
Popoemt's Avatar
I can hear the turbo spooling (my single turbo ) and it's a different noise.
2015 750i
2007 G35 (trade-in)
Old 02-21-2014, 03:49 PM
It happens with zero boost - usually at lower speeds <40 mph and around 1200-1500 RPM.
Old 02-21-2014, 04:24 PM
ImolaMMM's Avatar
I've got 15k now...
I've got everything but the B&O...
2006 750 Li-Retired
2006 330i-Retired
2002 M3-Retired
2000 323Ci-Retired
1991 M3-Retired
Old 02-21-2014, 04:46 PM
Mein Auto: Tampa
Strange... it sounded like a sound I had in my M5... Are you coasting when it happens?
2015 BMW X5M
2014 BMW M6 (Sold)
2013 BMW M5 (Sold)
2013 BMW Z4 35is
Old 02-21-2014, 08:17 PM
Usually under mid throttle - once it is whining, it will continue when I get off the gas pedal until I come to a complete stop, then it goes away. It was doing it a lot tonight so I had my wife drive while I sat in the passenger seat and I can't for the life of me figure out where it is coming from. It sounds like somewhere in front of the dash towards the passenger side, but I don't think you can hear it from outside the vehicle. Tried putting it in neutral and revving the engine - nothing. Tried power braking in drive - nothing. Pull away nice and easy from a stop sign - whine.
Old 02-22-2014, 01:30 AM
When I was googling this, 5-series owners (528's) were reporting it too. I believe the car in the video was a 2011 528i. Here's the original post:
http://www.e90post.com/forums/showthread.php?t=455691
Regarding one poster's question - yes, it can be heard when the cabin fan is turned off. To me it sounds like a high pressure valve release - sort of like a boiling tea kettle sound, but not as loud.
From reading other people's posts on various forums, the suspects were -
1) Leak in the air intake, but that was a 2001 car
2) Engine vent pipe clogged
3) Power steering unit (I doubt this because happens when the car is going straight or not)
4) Alternator (I'm assuming it would be the bearings, which would be heard outside the car as well. So if the sound is only heard inside the cabin, then maybe not the alternator...)
5) Small pebble stuck between the brake bad & rotor (person had this happen occasionally when they went down dirt roads)
The other stuff I found on the web read alot like this thread - people have heard, dealer has heard it, nobody found the source. Intermittent. Both times it happened to me was while driving slow, around 30 MPH. It could be happening at higher speeds and I'm not hearing due to wind noise / road noise. It happens if the car is neutral and the pitch reaches its peak at ~1200 RPMs. My car ~6500 miles on it.
Old 02-22-2014, 03:40 AM
Mein Auto: Tampa
I had a similar sound in my M5, and they "BMW" determined it was an issue with the drivetrain .... never found out what because I traded the car in before it was fixed.... In my case the sound initially sounded like it was coming from the NAV area, however when I had someone sit in the back seat, they determined it was coming from the back axel and the sound was bounding off the front windshield....
2015 BMW X5M
2014 BMW M6 (Sold)
2013 BMW M5 (Sold)
2013 BMW Z4 35is
Old 05-04-2014, 09:08 AM
Popoemt's Avatar
Anyone have any resolution on this? It's happening with more frequency for me now and is starting to get annoying!
2015 750i
2007 G35 (trade-in)
Old 05-04-2014, 09:51 AM
It is the crankcase vent valves. They are compromised in some way and the vacuum pressure is causing air to get through the seal and make that whistle. I have been battling the same issue and finally was able to get it to happen with the shop foreman at the dealership in the car with me. The easy test is to see if your oil filler cap is difficult to get off when the noise is occurring. I found a few videos of guys identifying the problem after googling BMW crankcase vent valve whistle.
On our cars now the vent valves are integrated into the valve cover so the entire part needs to be replaced. It took 2 weeks for my dealer to get it all done but it seems to have fixed it, although I could swear I've heard it very faint a few times since the fix. Could be me just obsessing about it now.
I'll see if I can get you some part numbers from my invoice - just have to find my folder.
Old 05-04-2014, 09:58 AM
Here's the tech commentary and parts info:
Cause: bank 1 and bank 2 crankcase vent valves - internal control valve deform
11-15-7-646-086 connecting line:111060
11-15-7-575-640 vent pipe:111066
11-15-7-646-087 connecting line: 111060
11-15-7-575-641 vent pipe:111066
Remove and install bank 1 and 2 = intake air box - harness
Install bank 1 and 2 vent valves and oil return lines
Good luck - hope this helps
Old 05-04-2014, 11:14 AM
Popoemt's Avatar
Thank you!!
2015 750i
2007 G35 (trade-in)
Old 05-07-2014, 02:45 PM
Popoemt's Avatar
Took my car in today for this, let's see if they can "replicate" it... The SA seemed to not care about my pre-diagnosis!
2015 750i
2007 G35 (trade-in)
Old 05-07-2014, 04:24 PM
CABimmerNation's Avatar
CABimmerNation CABimmerNation is offline
CABimmerNation
Mein Auto: 2010 750i M Sport
What? They usually love when we play doctor. Tell you know Raj, that should get you nowhere.
Dinan S3, PedalBox, 22" Agetro rims, H&R spt springs, RDsport front lip, coded, paddle shift retrofit, AlpineMSS HID 8000k. All exterior chrome, roof, roof spoiler and everything behind wheels painted black, wing, side and rear reflectors and door handle trim painted white, light smoke on tail lights. Audio: focal separates, earthquake low profile subs under front seats (crossed over as mid base to support the pathetic 4" fronts), arc audio amps, audiocontrol lcq-1 and epicenter, (2) L7 subs.
