E34 (1989 - 1995)
Old 02-21-2014, 02:04 PM
tward182 tward182 is offline
Mein Auto: 1992 BMW 525i M50 E34
Misfire 92 E34
My BMW is misfiring. Did a resistance check on on six coil packs and got a reading of 0.9 Ohm.
Fuel injectors have been changed. Had a little bit of oil on spark plugs. Going to change those and replace tube seals.
Any other ideas or advice?
Thank you
Tabor
Old 02-21-2014, 02:30 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Thank you
Tabor
Hello Tabor. Good to hear from you again. Does the misfire occur after the car warms up? I had a coil go bad (as have others here) and it tended to manifest when the car got up to normal operating temp. Thing is, the resistance was fine when I checked it when it was cold.
I have a spare that you can switch out with each coil to try to narrow it down if interested.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 02-21-2014, 02:39 PM
Hey Steve,
Thanks for the reply. The misfire starts as soon as you start the car. Sometimes I start it and it feels normal but a majority of the time it shakes pretty bad. I check resistance while engine was hot and all coil packs read 0.9. My concern is the oil on spark plugs.
I press the gas and it feels like the engine is running very rough and shakes.
Where are you located? Possibly could ship coil
Old 02-21-2014, 03:36 PM
Doktor Bert's Avatar
Doktor Bert Doktor Bert is offline
Der Sturm Uberdoktor
Mein Auto: BMW 525i
You can unhook the coils one by one and isolate a missing cylinder...
"Herr Doktor will see you now..."
Old 02-21-2014, 03:41 PM
How do I do that?
Old 02-21-2014, 03:57 PM
BMR_LVR's Avatar
Humble E34 lover
Hey Steve,
How much oil in the cylinder wells? If there is a lot, then yes, it can cause a misfire. I would recommend you inspect the spark plugs and replace them as needed as well.
BTW, I mistook you for another TWard that we have here on the Fest. Welcome.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
1992, coil, e34, misfire, oil, spark plug, tube seals
