Old 02-21-2014, 04:15 PM
RockChips RockChips is offline
Mein Auto: 2008 X5 3.0si
Question Where is this thing on our cars?
http://shoptalkwithjamie.weebly.com/...k-reviled.html
Old 02-21-2014, 06:09 PM
FredoinSF FredoinSF is offline
Mein Auto: 4 BMWs, 1 Jeep, 1 Vespa
Did you check there?
"the most common of coolant leaks are caused by a failed Coolant Temp Sensor located (in most cases) in the lower radiator hose"
That's where I would expect it.
I don't agree that it would be the most common cause of a coolant leak on a BMW though. Expansion tank hairline crack would be number 1 suspect, and on the E63 I would look for the smallish tube on top of radiator support panel.
