Car shaking - Bimmerfest - BMW Forums
Old 02-21-2014, 06:03 PM
bracer028 bracer028 is offline
Mein Auto: 2007 328i
Car shaking
I have 60,000 miles on my car. I was driving on the freeway and came to the exit. When i stopped towards the exit ramp, my car started shaking and then the engine light came on.
What could cause this.
Old 02-21-2014, 06:08 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
coil pack ?
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 02-21-2014, 06:11 PM
Ok i read a lot of people say its the coils too.
is this easy to change?
Old 02-21-2014, 07:39 PM
SilverX3's Avatar
Pretty easy 1 hour job... Youtube show you how
Good luck
Job - Captain
MY11.5 X1 Xdrive25i
Old 02-21-2014, 08:34 PM
Bemo's Avatar
Bemo Bemo is offline
Mein Auto: 2011 328xi
Change the plugs also while you're at it and also inspect the plug wells and valve cover gasket, for oil leaks.
2015 911 Carrera GTS
2011 328xi
2011 535xi GT
BMW CCA
Old 02-22-2014, 10:35 AM
Blessyouboys Blessyouboys is offline
Mein Auto: 09 328xi, 31 Model A
Before I started randomly replacing parts, I would get the codes read.
Old 02-22-2014, 12:14 PM
ctuna ctuna is online now
Mein Auto: 325xi wagon
yep get a scan it could be coils, plugs or injectors normally
Also a good visual check and fluid level check should be done.
Old 02-22-2014, 12:18 PM
Bemo's Avatar
Speaking of which, what is a good brand to buy? I emailed BT and was told that my 2011 E90 is not supported. Forum member fdriller suggested bmwcoding.com but reading about INPA is like rocket science to me...
I'll make the initial trade off of buying something user friendly in exchange for being able to scan/reset less components...
2011 328xi
2011 535xi GT
BMW CCA
Old 02-22-2014, 12:37 PM
Just saw this they have both android and apple version.
http://www.ebay.com/itm/Iobd2-BMW-Pr...m=121280652280
Doesn't look like much more than an elm with an app.
If you need to update software or do things like program in injector values
I think you need to go the Inpa ncsexpert route.
There was another program somebody had on here awhile back that allowed read
the BMW codes but there was no programming ability.
Yeah I found it
bmwlogger
You need to buy your own cable though.
Old 02-22-2014, 06:07 PM
Mein Auto: '06 AW 330xi
You don't really need to change the plugs.
I changed mine at 98k miles and the electrode looked fine.
