Old 02-21-2014, 10:53 PM
genghiskhan7 genghiskhan7 is offline
Mein Auto: 740LI
2011 bmw 740li - help
First and foremost. Great Forum...Getting some great informational reading on my first BMW.
So i bought a used 2011 BMW 740LI. First time having a BMW.
Few things:
1. Cabin Air Filter, how to change, tried to remove the necessary stuff, but couldn't find where they went.
2. Connected Drive, how does this work, it keeps saying it can't connect to the service center.
3. SOS, not working won't connect.
4. BMW App, is there an app that can control the car, turn it on or off, etc
5. HVAC, when I turn on the ignition, the HVAC Is always on, how do I turn this off.
6. Screetching noise when the HVAC is on low. When it is higher than 50%, no noise.
7. How do I delete songs from the hard drive? How do I add songs to the hard drive?
8. How do you remove the IPHONE dock in the middle console, It is attached, I don't have an IPHONE nor will I ever get one. Just need a bit more space.
9. How do I check which version of IDRIVE I have?
10. How do I download the most recent version of the navigation.
I think that is about it for now.
Old 02-21-2014, 11:17 PM
Snorlax Snorlax is offline
Mein Auto: _
Few things:
I think it is in the passenger foot well. There is instructions floating around here on how to do this.
You likely need the dealer to fix
BMW Remote app. Will find location and flash lights or horn. No turn on/off functionality.
Plug a USB formatted with Fat32 into the glove box usb port to import. Is is in the music options menu. You can also import regular Cd's there.
There are also instructions floating around here on how to do that. It is hard and requires some work. Not recommended for a newbie.
Not sure
You can go to the coding forum. There are threads there on how to do this. You need to buy an FSC code from a seller and then they will provide you with the files.
Welcome.
Do you have a wood parcel shelf on the rear of the car behind the rear seats?
